View Poll Results: Which size tire for a 18x8 wheel?
235/40/18
22.22%
245/40/18
77.78%
Voters: 18. You may not vote on this poll
18x8 wheel, what size tire?
Re: 18x8 wheel, what size tire?
Originally posted by Maximam
235/40/18
or
245/40/18?
See http://forums.maxima.org/showthread....hreadid=242472
235/40/18
or
245/40/18?
You should be putting a 235/40/18 on your 18x8 wheel. Trying to put a 245 on 8" will be a bit too wide and your car will not handle as well as it should. THe cars response time will suffer. If you want to use a 245/40/18 you should have purchased an 18x8.5 or an 18x9" wheel. Don't do the 245 on an 8" wheel, it will make you look uninformed. If you don't believe me, ask the pros. Call Tire Rack.
I have used 245s on two sets of 8" wheels and yes the sidewall is a bit over the edge of the wheel but not to bad. A 235 would be the perfect width if only the diameter was a bit larger.confused:
This is the delema I am having. I know the 235 is preferable but I am worried about the diameter being to small.
Originally posted by ajahearn
You also have to consider if your car is lowered. I have the Eibach's installed and 245 hits in the back.
sounds more like both matter
Originally posted by blubyu2k2
that has nothing too do with the series tire. Its the wheel offset, I am on Teins with 8" wide wheels and 245 tire with no rubbing.
245-40 look perfect on 8" wide wheels and within spec. Tire Rack specs 235-40 for 8.5" wide wheels also whats that tell you. Each tire has spec sheets that say what width wheel will work with the tire... by that not joe blow.
Re: sounds more like both matter
From what you are saying, it seems like you have to consider both the series and the offset.
Originally posted by Matthew
...Unfortunately .2 inches will make a big difference when calculatiing your miles on the odometer, especially over time, as well as the speed on your speedometer. Look at the poll results, go with the 245/40...
I think I know why so many people use the 245, they have SEs and are starting with a 225/50/17 tire.
I feel at this point this issue has no correct answer. If you want to match the diameter of a stock 17" tire go 245. If you want to match diameter of a stock 16" tire go 235.
My preference of width on a 8" wheel would be 235, I like a flush sidewall.
So unless anyone can convince me otherwise, I am going against most of the .org members opinions and going 235.
Actually, my GLE comes stock with a 215/55/16 tire. The 235/40/18 tire has the exact same outside diameter as a 215/55/16 which is 25.4".
Being a Tire Rack dealer, I can tell you that a 245 will work perfect on an 8" wide wheel. I have 245/40s on my 03 SE with 18" Moda R6s. Also, with the proper offset wheel, the 245s will not rub even if the car is lowered. The 245s also match the factory tire diameters the closest. They also match the tire/wheel load rating. Also, my tires fit flush with the rim. 235s have that "rolled under" look.
