Engine Knocking
Engine Knocking
During the last 2 weeks or so I've been hearing some slight knocking from the engine so I changed gasoline brands and moved up to super unleaded. I went to the dealership and was told to keep using super and try a different brand...that the knocking was pretty common, annoying but common!!!!
Am I being had by these people? I can't imagine that being a common thing? Any suggestions?
Re: Engine Knocking
BTW, you should ALWAYS be using premium gas anyways. Not that you should have nocking even w/ the lowest octane (unless you are flooring it) but I would definately have them look at it... if they give you more shiet... ask them to start up another car on the lot that does the same thing and prove your point.
Re: Engine Knocking
Second, you may have the infamous ignition coil problem 2000's had, so have your dealer run a check on your VIN for the TSB. It's in the sticky above I believe.
ballerchris510
09-23-2015 08:46 PM
ballerchris510
09-11-2015 05:29 PM
