rear brake, help!
Old 07-05-2003, 06:24 PM
flip's Avatar
rear brake, help!
i'm having trouble compressing the rear piston on a 2000 maxima. am i missing something? i have the bleeder screw undone and the cap off of the reservoir. it compresses but it is very difficult and does not want to compress past halfway. thanks ahead of time.
flip is offline
Old 07-05-2003, 06:53 PM
jonbth's Avatar
Some rear pistons are threaded and have to be turned, is there two notches or holes drilled in the piston for a spanner tool to fit it.
jonbth is offline
Old 07-05-2003, 07:30 PM
flip's Avatar
there are 4 notches. thanks for the tip. when it did compress i noticed it turning while compressing. do i need to turn it to compress it then? clockwise or counter?
flip is offline
Old 07-05-2003, 09:49 PM
Uconn411's Avatar
Use needle nose pliers to turn it clockwise.
Here's a writeup someone on the .org did a while back on replacing front and rear brakes:
Rotor & Brade Pad Installation Notes
My notes from rotor and brake pad swap without disconnecting brake lines or bleeding brakes.
Brake Install Notes:
Tools/Equipment:
• Jack & Jack Stands
• Impact Wrench or Lug Nut Wrench
• 14mm, 17mm, 19mm sockets & ratchet
• C-Clamp
• Rear Piston Compression Tool
• Mechanics Grease or Anti-Seize Grease
• Brake Cleaner
• Rubber Mallet
Front:
1. Put the car up on jack stands and remove the front wheels.
2. Remove the bolts holding the upper piece of the caliper on...14mm...these came off without any effort...slide the caliper off and hang it on the coil of the spring.
3. Remove the brake pads...they pop right off...pay attention to the way they are seated.
4. Remove bolts holding the lower piece of the caliper on...19mm...these require some elbow grease to remove, but I did not need any liquid wrench or a breaker bar...slide the second caliper piece off and set aside.
5. Remove the rotor...requires some rocking and tapping to remove...my stock rotors did NOT have a bolt hole easy removal so I did some light tapping on the back side with a mallet as I turned the rotor.
6. Install new rotor...clean up the wheel hub first and rub some grease around the hub to prevent the new rotor from rusting onto the hub like the stock one.
7. Reinstall lower piece of caliper...clean it up first to remove all the brake dust...tighten up 19mm bolts good and tight.
8. Install new brake pads...ensure that you remove the backing plates off the old pads and install them to the new pads.
9. Compress the piston on the upper piece of the caliper...loosen cap on the brake fluid resevoir by the driver's side strut tower in the engine bay to make piston compression possible...use a clamp and equally distribute pressure as you compress...watch for brake fluid overflow.
10. Reinstall upper piece of the caliper...clean it up first to remove all the brake dust...tighten up the 14mm bolts marginally (remember how easy they were to remove).
You're all done. Differences for the rears:
• You must remove the 14mm bolt holding the mount for the emergency brake cable to get the upper part of the caliper off...underneath the caliper.
• Lower piece of caliper is held on by 17mm bolts instead of the 19mm on the front.
• Piston needs to be turned clockwise to be compressed...I suppose you could use pliers, but you can buy a small piston compression tool which hooks on to a ratchet and makes life really easy...the one they sell at Sears has a piston pattern which fits the rear calipers on the Maxima.
• Make sure you hook the emergency brake cable onto the spring mechanism before reinstalling the upper caliper piece as it will be hard to hook back on after the caliper is assembled.
Here's a good tutorial for the front brakes to get a basic idea:
http://www.motorvate.ca/mvp.php/300
Uconn411 is offline
Old 07-06-2003, 02:25 PM
flip's Avatar
thanks for the help guys. i tried a search before posting but the links i got didn't work. i got the brakes finished with organic pads and i hope it will be a while before i have to do it again because that was a pain!
flip is offline
Old 07-07-2003, 11:58 PM
PsyKotiC RydeR's Avatar
nice write up Uconn. if it wasnt for this post i wouldnt have done the rear brakes. i thought my calipers were seized up at first but turning that on the caliper was annoying, but i got the brakes done.
PsyKotiC RydeR is offline
Old 07-08-2003, 01:26 AM
Uconn411's Avatar
No prob, I make it a habbit to copy anything useful I see into a word .doc, just incase it disappears....
Uconn411 is offline
Old 06-15-2008, 08:22 PM
shysmax's Avatar
Rear Caliper Tool
I realize this thread is old, but more the reason to post a pic here. I just changed my rear pads/rotors last week, and used a $17 rear caliper tool. I'm posting a pic bec. a pic. is worth a thousand words.
I've heard some shops rent the entire caliper compression set, but for the front, I use a C-clamp, and for the back, the tool in the pic below. Place the four "protrusions" into the caliper, and a 3/8" wrench on the other end, turn clockwise, and it works like a charm!:
Housecor has a great website, (thanks!) and I used his link:
http://www.innerbean.com/housecor/brake_install.html
and he linked maximafreak's site, which shows how to remove frozen rotors (thanks!):
http://www.cardomain.com/ride/351821/11
Use these links, and the downloadable FSM to determine proper torque specs, when tightening, and the caliper tool, and it should be an easy job.
shysmax is offline
Old 06-15-2008, 09:31 PM
wyche89's Avatar
it is a b*tch isn't it? i can't stand doing the rear brakes on our cars!
wow... WHERE did you get that tool, from that housecor website? that thing looks hot.. it looks like it works alot better than that flimsy @$$ auto zone rental tool.. man i can't stand that freakin thing...
wyche89 is offline
Old 06-15-2008, 10:45 PM
bgsl1ck's Avatar
I have one like it and I found it at AUTOZONE for less than 17 bucks I think I bought it about three years ago or maybe it was O reilly auto I can't remeber. (http://www.oreillyauto.com/EW3/HomePage.do)
bgsl1ck is offline
Old 06-17-2008, 07:34 PM
shysmax's Avatar
Bought the tool from autobarn. Nothing special really. $15.99 + tax. I figured better to buy it, rather than rent it every few years.
wyche89 - this tool (just like all the right tools for the right job) made the caliper compression easy.
shysmax is offline
Old 06-25-2008, 06:04 PM
MIXXMAX's Avatar
Yeah, I changed my rear pads a couple of weeks ago and ended up snapping that 14mm bolt off the emergency brake cable holding the caliper on the passenger's side. Now I cannot use my parking brake at all. The only fix around this is to buy a whole new caliper because it's built in part of the assembly.
MIXXMAX is offline
Old 06-26-2008, 08:13 AM
wyche89's Avatar
damn that sucks... how can one avoid snapping bolts when taking them off? just turn and pray?
wyche89 is offline
Old 06-26-2008, 08:28 AM
大陆弟弟
n3985's Avatar
mixxmax, I am selling two rear calipers with rebuild kit in the FS section
n3985 is offline
Old 06-26-2008, 08:49 AM
dot dot dot ...
NmexMAX's Avatar
I got that tool years ago for like 7$. I guess the price has gone up.
NmexMAX is offline
Old 06-26-2008, 01:00 PM
AJ~
AJ~'s Avatar
Autozone sells this tool. Just bought one a few weeks ago.
Each side has a different spanner configuration, so you can do brakes on probably every brand of rear caliper out there, assuming it is of the "twist piston to retract it" type.
Worth every penny. Don't remember what I paid, but worth it. So much easier and faster than needle nose pliers!
-AJ
AJ~ is offline
Old 06-26-2008, 04:39 PM
MIXXMAX's Avatar
Yeah, these bolts break very easily if over-torqued enough. Nissan is good for using soft bolts.
MIXXMAX is offline
Old 07-06-2009, 12:31 AM
rcjunkie's Avatar
2002 right rear caliper frozen?
I thought I'd piggy back off this thread to ask a question about my right rear caliper on my 2002 Nissan Maxima.
Because of a grinding sould coming from the right rear of the car, I took off the right rear brake pads to inspect it. The outer pad was not worn bad at all BUT the inside rear pad was worn at an angle on the outside edge and to the metal. I checked the inside rear rotor and it was also worn on the outside edge like the brake pad. What would cause this? A frozen seized caliper?
I tried to push the piston back in with a C-clamp but it was a no go. However, after reading through some information, I found that I may need a special tool from Autozone or some needle nose pliers to actually push and turn the piston in at the same time. Because of the uneven wear on the rear inside brake pad, I am thinking of replacing the caliper because it has probably gone bad and is probably still frozen causing the pad to wear unevenly.
Should I replace the caliper or is there anything else I can do to save the current caliper. One thing to note is that the dust boot on the piston is ripped. What does a new caliper cost and where is a good parts store to get it from; online or locally (I am in the SF Bay area if that helps)? Thanks in advance!
rcjunkie is offline
Old 07-06-2009, 01:42 AM
NissanTun3r's Avatar
LOL you have to have a specific tool that locks into the grooves of the piston, then turn it. I attatch the tool to a ratchet(it fits a 3/8 inch drive) with an extension and do it that way....
NissanTun3r is offline
Old 07-06-2009, 02:09 AM
DennisMik's Avatar
Originally Posted by rcjunkie
I
If the caliper was seized, I doubt that the pad would wear the way you described it. I bet whoever did the last break job wedged the brake pad in on an angle. There are "ears" on the metal brake pad backing plate that go in slots in the caliper to hold the pad in alignment and its not that hard to put the pad in wrong.
Besides needing new brake pads, the rotor may have to be replaced also, it may be too worn to resurface.
DennisMik is offline
Old 07-06-2009, 05:07 AM
phatboislim's Avatar
if u want my old rear caliper (passenger side) let me know ill send it to you...or i have teh driver side rear caliper also w/ the bracket
phatboislim is offline
Old 07-06-2009, 05:11 AM
actually yes it is really possible, because the same thing happen w/ my caliper, one side was more worn than teh other...i waited so long that my outer pad was metal to metal w/ my rotor..i had my rear brake parts i was waiting to get the money up to do my 04 front brake upgrade and do it all one day, but money was funny, so i went and did my rears...so yea your rear caliper is seized.
if u want my passenger caliper hit me up via pm and we can work something out
Old 07-08-2009, 04:07 AM
rcjunkie's Avatar
Thanks for the offer but I picked up a new caliper locally at a Napa store since I needed it right away since my work requires a vehicle.
It turns out I had a bad frozen rear passenger side caliper. Car is running great now.
Thanks for the replies!
rcjunkie is offline
Old 09-27-2009, 07:41 AM
maray's Avatar
Caliper tool
Autozone has the rear caliper tool for $11.99. Got one today.
maray is offline
Old 09-28-2009, 07:48 PM
n1_saxman's Avatar
I got one for $9.79 at Advance Auto Parts. I don't know that I want to do that job again though. It was quite a chore.
n1_saxman is offline
Old 10-01-2009, 06:00 PM
murphy390's Avatar
I had odd wear issues on my 01 rear brakes. Only 1/2 of the inside pads were making contact on the rotors. I tried the tool from AutoZone with no luck...couldn't crank them in. Also bought the "professional" set from Harbor Freight and broke that! I ended up getting A1 Cardone remanned calipers from RockAuto along with new rotors and the brakes work fine.
One note of recommendation on A1 Cardone remanned calipers (and probably most others)....PAINT THEM!. When they reman them they must remove any coating that was initially installed....probably sand blast them....and now they are rusting! Ugly but they work.
murphy390 is offline
Old 01-25-2010, 08:07 AM
icukev's Avatar
Thanks for the info on cranking the piston in for the rear brakes and the size of the bolt that holds the ebrake. I rented the tool from autozone but it didn't have the 4 points. It only had 2 which made it harder to turn. I used some WD-40 to help out. It took a while but finally got it done. Glad they don't wear out as fast as the front.
icukev is offline
mvm062
11-30-2020 09:00 AM
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
homeyclaus
09-03-2015 06:15 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: rear brake, help!
