Where to get front rotors for 02 max?
#42
www.southwestautoworks.com has Stillen rotors for 2k2-2k3 maximas.
#48
#49
I just hit gold. Check out this link:
http://www.2kracing.com/maxima-brakes.shtml
EDIT: I just spoke to Brembo and they only make rear rotors for 2K2 and later. This site is misrepresenting their stock of Brembo rotors.
#50
Re: Re: Re: Re: Where to get front rotors for 02 max?
Originally posted by Max_5gen
The pulling to the left/right while braking can be simply caused by the road incline. The first time this effect scared *** out of me. It happens at one particular place nearby when I'm on my summer tires. Somehow my summer set makes it much more noticable. If the car pulls to the side regardless of the road incline - something wrong with the brakes . Point here is that "warped" rotor doesn't cause that. It is responsible for steering wheel shimmy only and it is impossible to distinguish between two front rotors unless you have a good third one.
If I were you, I'd start from pads despite the dealer's opinion. It was discussed here many times that shimmy is caused by rotor surface buildup, not by "warpage". Pads play very important role in this process.
R4S pads are not for racing, racing ones called R4. Letter 'S' stands for "street use". I'm on the second set and have no judder/shimmy problems whatsoever. My dealer replaced my stock rotors under warranty and I put pads on myself right at that time. I forgot how my dealer's service department looks like since then . The only good outcome from my first set of stock rotors was that I've learned how to do brake service myself . I wish I made the experiment clean at that time and replaced pads only on my factory set of rotors but I was also thinking that rotors were warped. I've changed my mind after I actually measured them - they were close to perfect. I didn't know what to think after that. Then I found here explanation that rotor can have thin uneven layer on its surface with very different friction. That explained everything. So, you have to make sure that rotors+pads work well together on your car before buying them. Stock rotors + R4S/Raybestos Ceramic Quiet Stop seem to coexist fine. I don't have personal experience with Raybestos though.
Questions:
Where do you get your R4S?
How much?
How long they last?
Thanks.
#51
Check out this thread http://forums.maxima.org/showthread....hreadid=223258 We, 2kracing.com, have opened up a new site dedicated to rotors. http://www.performancerotors.com/maxima.shtml check it out it has performance rotors, brembo, ATE, powerstop... for all maxima gens.
#53
Now to pick... slotted or crossdrilled...
#54
Originally posted by Triple8Sol
No x-drilled/slotted huh...
So, what type of pads work best with crossdrilled brembos. I'm a fairly aggressive driver.
#55
Brembo Rotors we carry in stock for the Maxima production dates are as follows (81-84), (85-8/88),(9/88-94),(95-3/99),(00-01). For the 2002-2003 models, Brembo only has the currently for the rear.
We have the Brembo Rotors in the Cross-Drilled, Slotted, or the combination of slotted and drilled all in stock. You can order them at www.performancerotors.com
#56
#57
Ya, performancerotors.com does not show rotors for 2k+, we are still updating the site, its a new branch of 2kracing.com, but you can find those rotors on this page http://www.2kracing.com/maxima-brakes.shtml Sorry for the mix up
#58
#59
Also, unless I missed it the pricing is not consistent between the two sites. Performance Rotors is cheaper.
#60
"Brembo Drilled Front Rotors Fits on all Maxima (2002) $229.00 pair" We noticed that and already put a request to our webmaster, it should be removed soon. Yes performancerotors.com is cheaper, since the site is specialized with only rotors, we can keep the prices very competitive by only keeping track of one type of part. That is why we are pointing you guys out to performancerotors.com site, in the near future the rotors will be removed completely off 2kracing.com and performancerotors.com will have all the different Maxima gens. Sorry for all this confusion, maybe we should have waited till both sites are done, but I noticed this post and thought performancerotors.com would be a great site for such a part.
#61
#62
Re: Re: Re: Re: Re: Where to get front rotors for 02 max?
Originally posted by Teser
Thanks for xlnt explanation.
Questions:
Questions:
How much?
How long they last?
#63
Re: Re: Re: Re: Re: Re: Where to get front rotors for 02 max?
thanks a lot for the info.
30000 seems pretty good.
BTW, in my case, I still have stock rear with 54k on the car and looks like about 3mm of surface left.
Fronts were twice warped and serviced by dealer (last time about 18k ago) .Now rotors are warped again
So I'm researching my options.
I guess, I will listen to your advice, since you have some experience with it. I'm thinking on getting full set of R4S and putting them on resurfaced stock rotors.
BTW, I never worked on the brakes before. Would you recommend me to install them myself ( I have a great how-to manual ) or is it better let professionals to deal with it?
Also, how are the break performance comparing to stock?
And how do I order them?
Thanks for advise.
Thanks for advise.
#64
www.porterfield-brakes.com I actually called them and they have ongoing deal for .org members on R4S pads
71.20 fronts 55.2 rears + shipping. To get rid of judder fronts are enough. I was driving like this for two years: R4S front and el cheapo Vagner - rear. As with many owners here my stock rears were gone in no time, so I got Vagners instead. I wouldn't recommend them though - squeal like hell. This winter my brake cable froze and the car was on ebrake... God save those Vagner's souls.
fronts: ~30000 km, rears - have no idea yet.
Anyone found a distributor who actually has those Raybestos front rotors?
#66
Originally posted by PrinzII
I have a set of Metal Matrix pads and would like some better rotors.
Turns out that Nopi has the blanks. They can be found here: http://www.nopionline.com/index.cfm?...c&vaffid=0
#67
Originally posted by elmaximo
Thanks for the link. I think I am going to buy a pair of those for the front and machine the slots on them myself. Does anybody know how deep are the slots from the face?
#68
disclaimer: i am a complete novice with rotors/pads. thanks for any advice or info!
i checked out custommaxima.com and saw some POWERSLOT rotors:
http://www.custommaxima.com/PowerSlot.php
are these good for everyday driving? advantages/disadvan over raybestos? is the price fair?
they also recommend HAWK pads:
http://www.custommaxima.com/Hawk.php
any advice?
any advice?
#69
Re: Re: Re: Re: Re: Re: Re: Where to get front rotors for 02 max?
Thanks for advise.
#70
any advice?
any advice?
#72
Ok, I've got some terrific news! I just placed an order through CarQuest for Raybestos front rotors for my 2K2. They were about $55 each. CarQuest did not have a listing for the part in their computer or in their cross reference book. However, the guy I spoke to gave me the actual dealer number for Raybestos, which I called, and obtained the correct CarQuest number from them. When I called back CarQuest, I gave them the new number and they placed an order for me. The rotors are supposed to be in by this Tuesday.
What does this mean? Go to your local Raybestos parts supplier and ask them to call Raybestos to get the correct part number! These rotors are available. If anyone needs the CarQuest number, let me know and I will post it.
Also, I ordered up the Porterfield R4-S pads direct from the manufacturer for the discounted .ORG price someone else posted above. I should also have these parts by Tuesday.
My only remaining question is this: I was told that the pads will not come with the anti-squeal thin metal backing plate, do I need this? If I do I need one, and can anyone tell me where I can find them? Thanks!
#76
Originally posted by Stereodude
Those aren't the right rotors for the 02. Those are the same part number as the 01. Brembo doesn't make rotors for the 02. Also I did a lot of research and you don't want slotted rotors unless you're racing at a track and need to get the temps of your pads up real quickly. Slotted rotors just eat pads.
#79
I thought I'd provide everyone with an update. I picked up my CarQuest labelled Raybestos parts in the middle of this past week and I got the "special" Maxima.Org deal from Porterfield on their R4-S brakes. I did the install on the fronts today. Everything went together without so much as a single hitch. The only thing I didn't like was that the Porterfields don't have any wear indicators - not a big deal really since I change my pads at regular intervals anyhow.
I am pleased to report that my vibration during braking is completely gone AND most importantly that the Raybestos rotors look to be very well constructed and fit perfectly. In a direct comparison to the OEM rotor, they look almost identical. One distinction is that the OEM rotor has a thin "groove" cut into it about 1/2 inch above the hub circling it. The new rotors have no such groove. If these new rotors don't warp, then I don't really care.
Oh, one final note, I was very surprised to discover that the OEM pads on my 2002 were semi-metallic and not ceramic. For some reason I thought that Nissan was using ceramic pads on our cars? I guess I was wrong.
#80
Looks like I'll be getting a set of those Raybestos Rotors. I am getting vibration when braking. I am definitely going to get the Porterfields for the rear because the Axxis pads are dusting like crazy on the front.
