headlight bulb question
Old 05-26-2003, 11:11 PM
Darius's Avatar
on friday my friend gave me his H4 xenon headlights so i decided to put em in and they looked soo awesome. They were working fine the whole weekend until today. A few hours ago i went out to my car and turned it on and only my right headlight went on. The bulbs are 12V100/90W. Did i **** up my harnesses or did the bulb just burn out?
Darius is offline
Old 05-26-2003, 11:14 PM
clipse's Avatar
I'm guessing that the bulb just burned out.
clipse is offline
Old 05-26-2003, 11:40 PM
2001SE's Avatar
trying hitting the headlight house from the outside a few times...that sometimes should make it turn back on.
the temprature changes can affect that
2001SE is offline
Old 05-26-2003, 11:45 PM
Darius's Avatar
ok but you dont think the 100/90W thing is dangerous?
Darius is offline
Old 05-26-2003, 11:58 PM
ch13f's Avatar
Eh, I don't think the harness would have burned out so quickly... how about you try putting one of your old bulbs back in? I've been running 100/80 on the stock harness for like a year now and its been fine. I really should get around to upgrading it though.
ch13f is offline
Old 05-27-2003, 12:01 AM
2001SE's Avatar
sometimes i ask myself why not just get a 100% HID, no crappy bulbs and wattage. i wouldnt risk putting a higher wattage bulb..that will just burn your wires slowly.
2001SE is offline
Old 05-27-2003, 12:07 AM
Darius's Avatar
ok well i might just buy some replacements then. How do these look?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416763378
Darius is offline
Old 05-27-2003, 12:11 AM
scopium
most likely the bulb burned out
Old 05-27-2003, 12:12 AM
ch13f's Avatar
Honestly, your visibility in the rain will be gone with those... blue coated bulbs look good, but they really do suck.
ch13f is offline
Old 05-27-2003, 12:14 AM
E-Man01's Avatar
There could only be three options: 1. the bulb was touched and expolded prematurely 2: The bulbs were defective and just suck (like all halogen) 3. worst case-your harness is fried because of higher wattage bulbs. In that case the only way is to repair your harness if possible, so I would check your harness to see if it is damaged. Why not upgrade to HID? I contempatled getting 02 Hid lights for my 01 but instead got a Dual beam H4 4500k kit from Catz Hid that kicks @$$ . 02 Hids get stolen alot and the Catz kit is less that half the cost. Check my homepage for info.
E-Man01 is offline
Old 05-27-2003, 12:21 AM
Darius's Avatar
well, what do you suggest?
Darius is offline
Old 05-27-2003, 12:23 AM
Darius's Avatar
They're xenon bulbs... and your homepage isnt working
Darius is offline
Old 05-27-2003, 12:31 AM
SpeedinBlueFU's Avatar
You need some real HIDs wtf is this $10 bulb BS!
SpeedinBlueFU is offline
Old 05-27-2003, 01:02 AM
2001SE's Avatar
you dont have high beams now right?
2001SE is offline
Old 05-27-2003, 05:59 PM
E-Man01's Avatar
Actually I do have High beams, the kit I have is a Dual beam kit. The high beam works flawlessly; the kit wasn't hard to install, of course if you are mechanically inclined. The bulb moves forward to create a high beam, a soleniod clicks it back and forth when you turn the high beam on. Check out liteswap.com for info.
E-Man01 is offline
The Frye
09-02-2021 11:03 AM
Vistance
09-17-2015 05:17 AM
minsbang
09-11-2015 08:48 PM
mpbclutch33
09-08-2015 06:21 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: headlight bulb question
