new plugs.. wow, where to start!
I should have ordered from Dave, but I forgot to call him and really wanted to do it this weekend. So I paid the price, literally! $80 with tax from NAPA. ouch..
well, I was really beating myself about paying that extra $20 (with shipping)... until I finished and started the car! Oh my god... the first thing I noticed is that the car started in 1/2 the time... and that was after being moved, so I should have had a hard start.. not so, it started immediately.. no I mean instantaneously compared to regular starts. A few more starts were all the same, 1/2 the regular time.. My car has never started like that.
I took it around the block and it was pulling so hard. It was raining so I mainly broke tracting ALOT.. but I could tell it was really pulling harder.
AND FINALLY THE IDLE! smooth as hell.. I havent had an idle like that in 30K miles! AC/lights/fogs going and it was still smooth.. Every once and while I could feel a very subtle vibe, but nothing like the shuddering and loaping as before.
I guess the moral to the story is that if you had your coils replaced, then you may want to check those plugs too. Those bad coils really ate my plugs.. In fact, I think my plugs were toast at 10K. Only took me 30K more to realize it.
tell me why my keyless entry freaked out and it will be a truly happy ending :/ I reset (neg term off the battery) and it got better for awhile, not its not reponding again.. well, intermittant. *everything* else on the SECU seems to be fine. Bizarre.
I got the platinum.. however, now knowing how easy it is to swap them, it would be nothing to go copper and replace them every 30K. But its nice to know I wont have to worry about these for awhile (platinum), as my car has shown itself to be VERY hard on plugs.
this may sound dumb....but
Have you tried replacing your remote battery? Maybe? Just maybe???
Go plugs! Glad it worked. I just replaced all the plugs and wires on my Ford. It's idle still sucks a$$.
ARFF
IMO, I hated to replace the plugs on the rear bank. I had to remove some bracket to get to cylinder no. 5. after replacing them, my back was hurt and I was sweating like a pig.
other than that, I followed Hayne's manual and used a 8mm fuel hose to insert the plug back in. I would easily notice if I crossed a thread this way.
Most of my plugs were mushroomed at the tip like this one. Not really bad for a plug, but not in great shape either.
I just moved those cables out of the way on the rear. As far as the plugs going back in, I used the extension and plug socket. I turned it backwards a few turns, then forward. After a few turns, I pulled on it an made sure the plug was threaded in.. then continued finger tightening to the gasket... then popped on the torque wrench. My only shame is that I needed to stand on a block to get to that last rear one.. Being 5'10" can suck..
At last (driver side rear bank) was tough.. I used a 11" extension -> wobble ->6" extension. On torqing, I was *very* careful to keep the extension centered in the hole (when using the unversal joint).
I guess it was a bit easier for me because my car is lowered. I am 5'9, btw. I bet Kevin has no problem with it at all.
it is good to work on the car during the night, you get hella tired when it is done and you go straight to a good night sleep.
Re: new plugs.. wow, where to start!
I guess the moral to the story is that if you had your coils replaced, then you may want to check those plugs too. Those bad coils really ate my plugs.. In fact, I think my plugs were toast at 10K. Only took me 30K more to realize it. [/B][/QUOTE]
I replaced my plugs with OEM NGKs at 50K and had similar results although I did not have coil problems. I have now decided on replacing my plugs every 40K. If you run them longer I think any projected savings go out the exhaust pipe.
Originally posted by [maxi-overdose]
np..dont set it too tight because you have anti-sieze on it. with anti-sieze, the torque reading will be a bit lower.
great do I need to pull them out right away? or can I go for a week or two without?
it will just get tighter and tigher after more use and abuse.
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
trungg86
09-04-2015 04:58 AM
