Fog light wiring (not stock)
Old 04-04-2003, 05:15 PM
nissan5788's Avatar
I have instructions here on how to install foglights which I want to replace the stock ones with. It says, "...the wire should be connected to the low beam trigger wire which should have a positive 12V signal when you turn on the car's headlight switch...if your vehicle uses a negative trigger signal, you need to connect the wire to a switched power wire such as parking light."
What I want to do is have the fogs run either all by themselves or (if that's not possible) then with the parking light. If I can't run them by themselves, do I just splice that wire with the "trigger" parking light wire? Or is that not possible & I can only connect it to the low beam's wire?
Also, if I have to use the parking light wire for power, what color wire is it on the 2k2's? Is it the blue one w/silver? http://boostedmaximas.com/howto/fogrewire.html
Thanks in advance for your help!
nissan5788 is offline
Old 04-04-2003, 05:29 PM
BLaZin 2k MaX's Avatar
Re: Fog light wiring (not stock)
Wish I could help but im not sure. But, are you selling your stock? I want them.
BLaZin 2k MaX is offline
Old 04-04-2003, 07:24 PM
spta97's Avatar
I don't know your specific brand of fogs, but there should be no reason why you can't run them independant of the parking / head lights. However, you will need to switch them or they'll be on all the time. Depending on the wattage, I would get power directly from the battery, run to a switch, then out to the fogs. There should also be a relay in line (there were with the PIAAs my friend and I installed).
Just remember though, you'll have to flip the switch every time you want to turn them on and off. Might be easier to have them wired to the parking lights.
spta97 is offline
Old 04-05-2003, 02:40 AM
E-Man01's Avatar
maybe you can just wire them up to your original fog light wireharness, afterall it is relayed, fused and switched already. just use wire-taps and tap into the positive and negative of the wireharness and connect that to your fogs. I'm sure it'll work fine.
E-Man01 is offline
Old 04-05-2003, 09:26 AM
nissan5788's Avatar
Ok, there is a switch that comes w/the lights. They also have a fuse and relay. So, basically, I have to connnect the wire (which is supposed to be spliced w/the parking lights) directly to the battery and keep everything else the same as said in instructions?
I just want to get this straight before I start anything. There's three inputs to the switch. 1 - a ground wire. A 2nd input which is a white wire which comes from that wire coming from the relay to another ground loc. 3rd input is = a wire going to the battery?
The wiring diagram given by manufacturer..right click, save target as What do I need to change?
The reason why I want to go through all this trouble is b/c I want to have them running w/the highbeams. They're actually driving lights, not fogs.
Blazin2k, I'll let you know in a week or so. If I get these to work right, I'll sell the stock ones.
Old 04-05-2003, 09:28 AM
[QUOTE]Originally posted by nissan5788
[/QUOTE
Old 04-05-2003, 11:49 AM
2-Wheelin it...
PoLo's Avatar
as mentioned above, it would prolly look better and end up A LOT easier if you wired up to the stock wiring harness. this way, you can still use the fog switch on the headlight handle rather than placing a switch somewhere else on the car. tap into the wires and that should be it. if ANYTHING, why not snip the connector off your stock fogs and wire into that, so you really only have to snap the connector in and you're good to go.
one thing though, are these aftermarket fogs 35watt like stocks? if they are stronger, much stronger power, then perhaps tapping into stock fog harness isn't the smartest idea. but it's close, then i don't see a problem.
GOOD LUCK and let us know.
PoLo is offline
Old 04-05-2003, 12:09 PM
nissan5788's Avatar
These are fogs that use the 55W H3 bulbs. I had these same ones on my Grand Am and for that, I had to use the relay provided but still was able to use the stock wiring and use that as power so I didn't need the switch. Provided I have to use the switch, does anyone know which wiring in that diagram I have to change? Just hook up the red wire from the switch to the battery (pos. or neg.?) and leave the rest as is?
These lights are great, on my GA, I could practically drive around w/o headlights on at night and was still able to see great. These + HIDs would be even better! In case anyone's wondering they're BlazerTech 3200 Driving Lights. They also make 2200 fog lights which are a true yellow.
Old 04-06-2003, 10:13 AM
nissan5788's Avatar
Bump + yet another question
Okay, what about in Russ' fog rewire instructions...which wire are you supposed to tap into on a 2002 (9th step, "Soon to be updated for 2k2 install on which light wire to tap into" )?
Russ' Fog Rewire Instructions
This, I know some of you 2k2'ers have done. Can someone please reply back w/that info? Thanks!! (I really want to get this done by tonite )
vingodine
45
05-21-2016 12:46 PM
EuroDriver
09-14-2015 06:08 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
98nismomax
08-13-2015 12:44 PM
Quick Reply: Fog light wiring (not stock)
