6-speed much smoother now...ABOUT TIME!!
Old 03-14-2003, 06:36 PM
2-Wheelin it...
PoLo's Avatar
just swapped out the OEM icky brown fluid for Redline 75w90.
first thing i noticed RIGHT AWAY was how the clutch drops like nothings attached. it feels SO SO SO soft, and the gears, let me not say about the gears...smooth shifts. even the infamous 2-3 shift is noticably smooother. i'm a happy 6-speed owner now. must thank greg at greghome.com for the right size of the hex bit. thanx a lot whoever you are.
PoLo is offline
Old 03-14-2003, 07:12 PM
tita6's Avatar
Re: 6-speed much smoother now...ABOUT TIME!!
I have used MT-90 in my old 240SX with similar improvement.
I am very interested in trying something new to make shifts less clunky in this 6-spd.
Anyone else had similar results?
tita6 is offline
Old 03-14-2003, 08:22 PM
vqman
cool...I might try that...what did it cost you?
I usually don't have problems going from 2nd to 3rd, usually from 6th or 5th to 3rd is when I get my grinding...
-vq
Old 03-14-2003, 09:34 PM
FastMax'02's Avatar
I just put it in on Tuesday.
May shifting is SOO much smoother.
All the shifting is smoother and lighter.
I can now shift into first and second in cold weather.
Compared to my other shifts my 2-3 shift still is not perfect but it is about 80% better.
It will cost you about $30 bucks for 3 quarts.
FastMax'02 is offline
Old 03-15-2003, 10:39 AM
Jaws's Avatar
My shifts are a lot better with the MT90 and as the mileage adds up, the shifts are getting better and better. I've got no issues with the shift quality now, not butter smooth but not clunky either.
Jaws is offline
Old 03-15-2003, 10:45 AM
max...to the ma's Avatar
gotta get that stuff! where did u buy urs?
max...to the ma is offline
Old 03-15-2003, 12:15 PM
SupaFly's Avatar
Just changed my fluid today to mt90. I drove it around and the SES light came on. I disconnected the battery, hopefully it will help.
Shifts are feeling really good now. Nissan should sell the cars with this stuff!
SupaFly is offline
Old 03-15-2003, 09:16 PM
2-Wheelin it...
PoLo's Avatar
myoilshop.com
i don't know the coupon code but there is one for .org members....i'd say do a search, but you know...non-donating members get screwed..=)
PoLo is offline
Old 03-15-2003, 09:25 PM
SupaFly's Avatar
myoilshop.com
What are friends for?
Redline Products
www.myoilshop.com
Enter dealer code #675421 for 10% off.
SupaFly is offline
Old 03-16-2003, 05:37 AM
Lonz's Avatar
How many quarts did you buy? I can't find the capacity for the manual tranny in the owner's manual.
Lonz is offline
Old 03-16-2003, 06:02 AM
iwannabmw's Avatar
Buy 3 quarts for the 6 speed.
iwannabmw is offline
Old 03-16-2003, 06:04 AM
Lonz's Avatar
Thanks!
Lonz is offline
Old 03-16-2003, 07:29 AM
2-Wheelin it...
PoLo's Avatar
oh yeah, an FYI, i didn't know this, and maybe some of you dont' either. it is impossible to overflow a manual tranny with fluid.because of the fill hole is vertical, you keep on filling (the car should be flat and not on ramps) and at around 2.5 quarts, when you see it start to overflow, you're done.
PoLo is offline
Old 03-16-2003, 02:48 PM
UCF_94lude's Avatar
I just ordered mine. I really hope this helps mine as it did you guys!
UCF_94lude is offline
Old 03-16-2003, 02:54 PM
specialist23's Avatar
how do u drain it. not having my car or my owners manual right now, there's not a way for me to check but i would like to know. thx.
specialist23 is offline
Old 03-16-2003, 03:05 PM
SupaFly's Avatar
Go here... Greg's Home
SupaFly is offline
Old 03-16-2003, 05:14 PM
nismotech's Avatar
MT-90 is the $hit~
nismotech is offline
Old 03-18-2003, 07:07 PM
ynot411's Avatar
Just changed mine too!
Should be the 1st mod done to the vehicle. Have had noticable difference in shifting compared to stock gear oil. Only down-fall it's like $9 per quart. Just wish I went to the website early.
ynot411 is offline
Old 03-18-2003, 08:14 PM
njmaxseltd's Avatar
Why would changing your tranny oil have any effect on your clutch pedal feel? It's a completely isolated system and doesn't come in contact with your tranny fluid or the internals of the tranny itself. It only enguages the engine to the input shaft.
njmaxseltd is offline
Old 03-19-2003, 10:00 AM
MaximaMan77's Avatar
Re: Re: 6-speed much smoother now...ABOUT TIME!!
Thats what I was thinking...
I love the stuff it really smooths out the shifts but does nothing for the clutch.
MaximaMan77 is offline
Old 03-19-2003, 10:17 AM
maximilion's Avatar
Sorry if I sound stupid, but which is better for everyday driving? I live where cold is 65 and hot is 85 degrees. MT-90 or 75w90(?).
maximilion is offline
Old 03-19-2003, 10:20 AM
You need MT-90 weather is not the factor, warranty is MT-90 is GL-4 (I believe thats the rating) which is what is called for in the manual.
Old 03-19-2003, 10:22 AM
maximilion's Avatar
Polo, why did you choose 75w90 over the MT-90?
Old 03-19-2003, 11:12 AM
2-Wheelin it...
PoLo's Avatar
ok, i guess i confused some people...the description of myoilship.com for the oil i chose says this:
MT90: Manual Transmission Lubricant - a 75W90 GL-4 gear oil designed for use in manual transmissions and transaxles.
so i said 75w90, which it is, but i meant MT90, which is the same thing. the other oil they have is MTL, which is a 75w80 based gear oil.
PoLo is offline
Old 03-19-2003, 11:33 AM
PCGuRu2K's Avatar
is it the same for a 5-spd? 3qts?
PCGuRu2K is offline
Old 03-19-2003, 11:50 AM
maximilion's Avatar
Re: Re: Re: 6-speed much smoother now...ABOUT TIME!!
thanks for clearing that up.
Old 03-19-2003, 12:46 PM
jnovember's Avatar
5-spd = 4qts. I bought 5 when I did mine and used a little more than 4.
jnovember is offline
Old 03-19-2003, 05:09 PM
PCGuRu2K's Avatar
Thanks!
PCGuRu2K is offline
Old 03-20-2003, 04:21 AM
iwannabmw's Avatar
Yep, definitely buy 5 quarts.
Old 03-20-2003, 05:41 AM
PCGuRu2K's Avatar
Cool.. I just placed my order. Hopefully I get it by next Fri cuz I'll be off from work and can install it then
PCGuRu2K is offline
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
kjlouis
10-03-2015 05:29 AM
trungg86
09-04-2015 04:58 AM
Wareagle92
09-03-2015 07:18 PM
Quick Reply: 6-speed much smoother now...ABOUT TIME!!
