Check Engine Light
Old 11-13-2002, 12:54 PM
Revice's Avatar
Check Engine Light
HELP!!! My "Check Engine Light" Came On. I have 53K miles, car normally runs fine. Suddenly it came on, car shakes when its cold. Does anyone have any suggestions?? anthony_gilmore@acordia.com
Revice is offline
Old 11-13-2002, 01:32 PM
Dohcser's Avatar
Re: Check Engine Light
Did you check your gas cap? If you recently took your gas cover off and did not put it back on properly the Check Engine Light comes on. Also if you have extended warranty or if your service is cool they can pull up the code and tell you what the problem is.
Dohcser is offline
Old 11-13-2002, 01:36 PM
njmaxseltd's Avatar
I shake when I'm cold too. Brrrrr..
Kidding, sounds like you have a misfire. Have the code pulled and you'll know exactly whats wrong.
njmaxseltd is offline
Old 11-15-2002, 06:58 AM
plmafia16
If you don't have a warranty on your car anymore don't go to nissan for them to figure it out. You can buy a code scanner for your car. This is what i did. the dealer wanted $75 to figure out what was wrong. Then i bought a code scanner and i found out the problem myself. i bought it for about $180.00. It was a good buy.
Old 11-15-2002, 12:49 PM
QUEDOG9's Avatar
Where can I purchase a code scaner from?
QUEDOG9 is offline
Old 11-15-2002, 05:00 PM
ATt
ATt's Avatar
go to autozone they check for free
ATt is offline
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
beboski
08-16-2015 05:23 PM
Flores94
08-11-2015 12:53 PM
Quick Reply: Check Engine Light
