KYB AGXs...finally...
well, my left front Tokicos were blown(the rest 3s were kinda ok) so got the KYB AGXs for my car and installed it today.
before install, i knew i had to modify the top strut mounts but i also found out that one of the strut bolts on each front strut also had to be modified. the spaing between the 4th gen holes were shorter than on 5th gens. so i ended up elongating the holes to fit on my car. am i the only one with this problem? the struts fit fine after and there are no noises from the suspension.
oh btw, the AGXs are really nice shocks. Tokicos were good but these are absolutely better!!
I got Tokicos for the front and KYB AGXs for the rear. Now I'm concerned that I'll have to get the Tokicos replaced in the near future since people have had problems with them. You and Myktek have failed Tokicos in the last month alone. This sux because I have to pay for the installation each time .
How long were the Tokicos on your car before they failed?
My setup matches yours Tanman...this is the first I've heard of the Tokicos failing recently on the 5th gen fronts...who else had the problem and what springs were they running...I have Eibachs...
I really hope the Tokicos last because I don't want to pay for a second install, plus the mess with warranty replacement on the Tokicos.
Originally posted by irvine78
that's the thing with the shock warranties. it's really a biatch!
Looks like I'll have to learn how to install them on my own . Good luck getting yours replaced under warranty, then sell them like [m-o] suggested.
Well, the streets of Houston aren't good for shocks, lots of bad pavement. I don't slow down for it either, same way with speedbumps. When I gotta go, I gotta go.
good luck with your install..
With some luck I should have mine in as well by Stillen Day...I am looking forward to ripping my car apart again, replacing the shocks/struts and all the wheel studs I jacked up last track day...
Re: KYB AGXs...finally...
Re: Re: KYB AGXs...finally...
Originally posted by Burton069
Hey where did you get the KYB AGX and for how much?
Originally posted by zoner
Hey, I'm probably going to get blasted for this, but I can't find out where the AGX shocks are sold w/ the conversion pieces for a 5th gen. Help???
Cattman is selling the AGXs with the conversion kit for $450.
the conversion kit is still 4th gen AGXs with the 4th gen strut mounts. you still have to elongate one of the strut holes in the front.
Maxima_Joe
11-25-2015 08:19 AM
maxima-junky
10-07-2015 06:13 PM
dvcamp
09-18-2015 10:17 AM
