I tried, How do you remove the center console!!!
Old 08-05-2002, 12:45 PM
radpp16's Avatar
I have an AUTOMAGIC!!! All the directions i can find are for 5-speeds.
I removed the ashtray screw, cubby scew, and 2 screws on each side at the base of the console in back. It still is attached somehow at the shifter area. I can lift the console up but i see my stock fake wood bezel area bending up. I dont want to break it. What am i doing wrong here? I am removing it so i can install the leather e-brake boot.
Roger
radpp16 is offline
Old 08-05-2002, 01:03 PM
Old Fuddy Duddy
Colonel's Avatar
Re: I tried, How do you remove the center console!!!
Roger
PM me your email....
Colonel is offline
Old 08-05-2002, 01:45 PM
krazyd's Avatar
I need to know how to do this too. I'm also driving a 5th gen automatic
krazyd is offline
Old 08-06-2002, 07:11 AM
Old Fuddy Duddy
Colonel's Avatar
Sorry so late
I have been sick since last night...thats what I get for screwing up my medication...anywho...I have sent an attempt to explain to the sent email...if it works for ya let me know!
Colonel
Colonel is offline
Old 08-06-2002, 07:20 AM
Y2K2Driver's Avatar
This is from the 2k2 ESM, but I know others have used with success for previous 5th gens. I don't think there is a difference between auto and stick because the ESM only gives one description. Hope it helps.
http://mywebpages.comcast.net/mpillm...sh_removal.pdf
Y2K2Driver is offline
Old 08-06-2002, 07:33 AM
ms.thicknes's Avatar
Roger
ha ha...you ran into the same dilemma that I did
there are two screws under the shifter boot that have to be removed...then the trim snaps out of the pockets on both sides
open up the cubby hole in the center console and peel back the felt..there is another screw there
there are two small screws on each side by the edge of the seats...push the seats back and take those out...then push the seats foward and remove the two that are on the bottom and closer to the rear ashtray/lighter element
once you print out the pdf directions..it makes all the sense in the world...but once you put it back in...TEST AND MAKE SURE THE REAR ASHTRAY HAS ROOM TO SLIDE IN AND OUT cause if you don't you have to take all the screws out and make sure you have it aligned correctly
I was so proud of myself when I took it out!!! Have fun and drink a beer when you are done
ms.thicknes is offline
Old 08-06-2002, 07:57 AM
Igor911's Avatar
Re: Re: I tried, How do you remove the center console!!!
Yea it took me a while to find those screws under the felt too.
Igor911 is offline
Old 08-06-2002, 08:46 AM
krazyd's Avatar
Thanks for the PDF file. It's going to help a lot, I can tell already!
krazyd is offline
Old 08-07-2002, 04:23 PM
radpp16's Avatar
ebrake boot is on YAY
THanks alot, It helped!!! I did it, the boot does fit tight, i cant believe i had to make my own little holes inthe leather.
THanks all
Roger
radpp16 is offline
Old 05-01-2012, 06:48 PM
EvoTillIDie's Avatar
bump to an ancient thread lol i was wondering if this pdf is still around?
EvoTillIDie is offline
Old 05-01-2012, 07:24 PM
RR5
RR5's Avatar
Directions are in the FSM, link is here >> http://www.nicoclub.com/FSM/maxima/
RR5 is offline
Old 03-06-2013, 09:35 AM
kingnissan's Avatar
do u still have that pdf file by chance?
kingnissan is offline
Old 03-06-2013, 05:01 PM
cjandura's Avatar
Originally Posted by supra11
I have removed center console few times and it should move with ease, thats how i know every screw is out...it should not difficult or stubborn to remove, otherwise it will break
7 screws make sure you get the one inside the storage area and the 2 at the bottom in the back
cjandura is offline
06-06-2017 02:01 PM
gigabyte
01-06-2017 06:05 PM
RealityCheck
10-02-2015 06:34 PM
jaydot901
09-29-2015 01:18 PM
Quick Reply: I tried, How do you remove the center console!!!
