PA 00VI power rod block off plate
Ok so I removed the power rod on my dek and made a blockoff plate for a cleaner look. Figured I'd offer to make another if anybody else wanted one. It's made of out 1/4inch thick aluminum and will come with new bolts and washers to replace the oem screws. Also this will allow those using a pftb to retain cruise control.
Price would be 35shipped
step 1
remove the uim
step2
remove the two screws on the passanger side of the intake and remove the cover
step3
remove the four screws on the vias box and remove it
step4
pull out the power rod
step5
put the cover back on the passanger side and two screws
step6
put alittle rtv on the block off plate and put it on with the supplied screws and washers
step7
put the uim back on
step8
enjoy
remove the uim
step2
step3
step4
step5
step6
step7
put the uim back on
step8
enjoy
I am about to start on a turbo project so once the remaining three are gone that maybe it for awhile
Looks interesting... This might be off topic a bit, but how can I tell/test my VI to see if it's working or not? I'm thinking about buying a blockoff plate if it doesn't hurt my midrange too much. I do alot of stop and go commuting in heavy traffic. Do you have any before and after dyno results by any chance?
Pulled the power rod yesterday. Definitely felt more topend. Also acceleration is much smoother throughout.
About the plate, are there similar grooves like the vias box or is it a flat plate?
yep, paypal is inzom@yahoo.com
I had this on my turbo, dek swapped 4gen. This works better with boost or an extended rev limiter than a bone stock car
