PA 00VI power rod block off plate
#169
Its super easy.
-Unbolt the vias box and pull it out. Make sure the cup that holds the rod is in there (dont want that lil **** falling into the IM )
-On the direct other side of the IM (passenger side), unscrew two screws on that little plate opposite the vias box.
-Pull out power rod (theres a chance you have clearance issues with the ac line being right there but nothing difficult)
-Put everything back together and enjoy.
I can snap pics for you if you like.
#170
Its a little, metal cup that fits over the end of the powerrod. The cup should be attached to the vias box and turn when the actulator arm moves.
Fyi I would suggest just taking the uim either off or really lose and use vise grips on the screws
#172
Got my blockoff plate and was hoping to install this weekend, but it's already 90 degrees outside and highs this weekend are going to be 95+, so I'll wait until next weekend to get it installed
#174
I'm installing the block off plate this am, does anyone have had code since the removal of the 2 switch ? I'm thinking of leaving the switch plugged in so no code will show up. Also I see it was suggest to put RTV, is this silicon ? Sorry but my french brain doesn't have a clue of what is RTV. Lol
Edit: I went to the local store and got the RTV Gasket.
#177
#183
I was against this at first since I'm auto and was told I'd lose low end but I don't believe that and I know my VIAS is fuked my car has 190k and I'm not dealing with fixing it and having to worry about it going bad again!
#188
#193
#199
