The Ultimate 03 Maxima SE/TE Partout......BOOM!
#242
Want the center console plastic vent cover
How much for the center console plastic vent cover? I want to replace my stock with your silver-painted cover. Can paypal, live in Raleigh, NC.
#246
#247
Play with my balls
I need the 3 plugs circled in red below, along with the 3 under the intake manifold connected to the rear fuel injectors. Basically, I just need the 6electrical plugs to the fuel injectors, along with a decent amount of leadwire to each, so I can solder them into a new harness. Ready to purchase. Thanks.
Got ya.
#248
Didn't I buy the full engine control harness from that car? If so, then those injector connectors are on my harness.
BTW, I need the two o2 sensors that are further down the exhaust stream. They are called "Oxygen Sensor #2 Bank 1" and "Oxygen Sensor #2 Bank 2". I don't need the ones that are in the stock exhaust manifolds up close to the heads.
Give me a call back on my cell as soon as you know. Thanks.
#249
#250
I called P a little while ago and left a voicemail asking about them and then I noticed this thread.
I am also in need of a midpipe to connect my TB to MAF. I'd prefer if it was a decent aftermarket piece so I can easily tap my nitrous nozzle in it.
#252
I wish I could help ya, but I got nothing. Sorry.
#253
Sorry man. I have a QR25DE engine harness here and was hoping that some of the injector connectors were on it, but it's not. Those 4 connectors must be on a subharness connector. And I couldn't find any other connectors on that harness that would work for you. I also have 3 VQ35DE injector connectors that came on my engine from the salvage yard when they cut the engine control harness. But they cut those 3 connectors flush with the connector!
#254
Play with my balls
Hey guys. I'm going to my motor now and verifying for sure. You guys might be right, and they might be on the main harness, but I thought that there was a secondary harness for these. I'll check and report back for sure.
#256
So you should have 3 of the connectors he needs.
#257
Hi, do you still have the shifter assembly? Will you separate it out or must you sell the entire assembly together?
Thanks,
Mike
Thanks,
Mike
#259
Play with my balls
The harness I bought from you has 3 LH injector connectors. But the RH injector subharness is still on your car I bet. It is the same exact stretch of wire that has the oil pressure switch connector and is attached to the bracket for the EVAP solenoid.
#265
You wouldn't happen to have a spare o2 sensor connector, would you? I need the male connector that goes on the sensor itself. I would prefer that this came off a bad o2 sensor. I just need the pigtail.
Edit: Here's the connector I need:
#266
#271
Hey man, I need these:
http://forums.maxima.org/5th-generat...ml#post6977920
Please let me know if you have them.
#272
Play with my balls
PM Sent
The one in this thread is not available, but I have and Eclipse 6610 for sale if you're interested.
This isn't available anymore. Sorry.
