I just pulled my engine out of my parts car. Car had 121k and ran very strong, no smoke or oil consuption. I'm located in Richmond Va. Engine was carefully removed, no wiring cut or ripped out. Included are the coil packs, injectors, engine cover, power steering pump, alternator, exhaust manifolds with front manifold o2 sensor etc. You get entire engine as you see it, minus the torque converter.
Pick up ONLY.
$550 COMPLETE engine with all accessories attached and with main harness ( no cut wires) with ecu.
Also have the auto transmission.....$150 torque converter included
Pick up ONLY
__________________
01 AE: Stillen fstb rstb rsb, K&N CAI, S-Tech, Tokico, F/R drilled slotted with Hawk pads, clear markers, high temp headlight fluid, eyelids, 35% tint.
