STRUT/SHOCK Alternative
Old 08-08-2018, 10:13 PM
Jim298's Avatar
  • As is common knowledge, a lot of parts are interchangeable between models. So my question is, is there a “off the shelf” shock/strut or from another Nissan model that would be suitable for the a32 that wouldn’t require shortening and be ready for a lowered spring straight away? I know a lot of the time a s13 strut is used across a range of cars, not just Nissan, as a ready to use, easily accessible, short(er) shock. I’ve tried ringing suppliers (in NZ) and they aren’t much help.
Cheers
Jim298 is offline
Old 08-09-2018, 07:33 AM
KP11520's Avatar
If Koni STR-T (orange) Struts are available there, try them instead.
They are made to use full size springs and are just as comfortable with shorter springs. I believe up to 2" shorter with no problems. Reasonable and also ride a little more sporty than OEM struts. More predictable and a little firmer.
8750-1065R Front Right
8750-1065L Front Left
8050-1126 X 2 Rear
Just know, when you rebuild Maxima struts, Use OEM parts for everything but springs and struts. Nothing aftermarket lasts as long with less problems. And make sure you use these front insulator assemblies for best results:54320-40U02
KP11520 is offline
Old 08-09-2018, 07:40 AM
Jim298's Avatar
Unfortunately we don’t, we really only get basics and maybe 1 or two premium models. The orange is something I haven’t come across. And I dare say it’d be super costly to import too.
Jim298 is offline
Old 08-09-2018, 07:50 AM
KP11520's Avatar
You might be surprised if you can source them. Compared to OEM Nissan prices which are stupid money for Struts! STUPID MONEY! And not as good!
Maybe contact Koni direct and ask what the cross reference numbers for NZ. But you can get Koni there. http://www.georgestock.co.nz/KONI-Shock-Absorbers.asp
http://speed.co.nz/page.php?pid=35
KP11520 is offline
Maxie40
19
07-24-2018 02:47 PM
hooloovoo
06-16-2018 03:57 PM
Warik
31
01-26-2006 06:23 AM
soundmike
08-03-2005 08:11 AM
99maximagxe
06-12-2004 03:50 PM
Quick Reply: STRUT/SHOCK Alternative
