Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-23-2002, 06:04 AM   #1
Knock Sensor Symptoms
Does anyone know what the symptoms are for a Knock Sensor being bad.
I drove my car for 20,000 miles with the mil light on and new I had a code 130 and 150. I did not notice any loss of power. I now have a loss of power and the car dies sometimes when I come to a stop. I just did a diagnostic check and I have Oxygen Sensor Right(130) and Left bank(150), Speed Sensor(500) and Knock sensor(325).
__________________
BattleBotsJudge
BattleBotsJudge is offline   Reply With Quote
Old 04-23-2002, 09:44 AM   #2
Send a message via ICQ to SuDZ Send a message via AIM to SuDZ
Bad knock sensors can give bad gas milage.Bad performance , as in less power. thigns to that effect.
SuDZ
__________________
'98 Se 5 Speed.
My Cardomain site for my Z
SuDZ is offline   Reply With Quote
Old 04-23-2002, 09:55 AM   #3
Most people on the org have suggested that the KS codes tends to come on as ride along to O2 sensor problems sometimes and if the problem of the O2's is corrected and it STILL comes on then it needs to be changed.
To me, it sounds like your car has other issues besides the KS. I would address the sensors first, reset the ECU, and if the KS comes back THEN change it. It is not a super cheap sensor and a real pain to reach, but can be done with a very long extension, swivel, and a 12mm socket.
__________________
With the Maxima that's in ICU:
TSC Member#6
13.335@108MPH- 08/23/02
OBMC Member#42
JAIMECBR900 is offline   Reply With Quote
Old 04-23-2002, 01:18 PM   #4
Re: Knock Sensor Symptoms
Thanks for the information. I am in the process of purchasing the sensor's on line and will forward my results.
__________________
BattleBotsJudge
Old 04-23-2002, 01:26 PM   #5
I measured the resistance of the Oxygen sensors and they were at 5.9 ohms. The shop manual say's it's supposed to be around 2.3 to 4.3 ohms, so I will order them today. I measured the resitance of knock sensor and it was out of specification? Although, I am not sure though that I found the right knock sensor connector. I will reverify the connector location tonight. Thanks for the post.
__________________
BattleBotsJudge
Old 04-24-2002, 03:02 PM   #6
hey I have a 95 gxe and it kept stalling with out any notice as well, took it to the dealer and they said it waqs either the knock sensor, coolant valve sensor or the purge volume control connector = $850.00 to repair all 3. I was not going for it! I had the first 2 problems fixed and really didn't need the third fixed and paid less to get it done. get the coolanr valve senor fixed first ($48.00 part)and see if you have the same problem, if still acting up, then get the knock sensor fixed ($125.00 part). hope this helps just passing on the knowledge.
bbrown is offline   Reply With Quote
Old 06-09-2002, 09:14 PM   #7
Quote:
bbrown,
Thanks for the information. I bought a knock sensor but did not replace it because when I checked the resistance it was okay. I will order the coolant valve sensor first.
Sorry for not responding sooner, BattleBots Judge.
__________________
BattleBotsJudge
Old 06-10-2002, 07:24 AM   #8
bbrown,
Hey, no problem, after I got the coolant valve sensor, no more engine cutting off.
good luck
Old 06-10-2002, 09:26 AM   #9
I have a '95 GXE w/ ~90K miles. The knock sensor was replaced at ~40K miles and I fear it it is going bad again. The MIL has not come on and it did not come on when it malfunctioned previously. My symptom is a noticable loss of power at low RPM's, almost like a stutter or miss, and bad gas mileage. I've read that these are not too difficult to replace. Can anyone send me information on where it is located and how to replace it? Also, where's the best place to get parts these days? A have always dealt with Courtesy Nissan in the past.
Mattw is offline   Reply With Quote
Old 06-10-2002, 09:50 AM   #10
Send a message via AIM to ericdwong
Hmmm this is curious. On my way back from the NE meet yesterday, my CEL came on. Today I pulled the code and it was the 0304 which is the front O2 sensor. Its possible I did not put it in right or I busted a wire after doing NUMEROUS Y pipe /OEM pipe install/deinstalls.
Since I should be getting my damn Y pipe back soon I will swap the front and back O2 sensors and see if it changes anything.
I then tried the resistance check on my Knock Sensor. I had my ohmmeter set to RX 1K range and the meter read in the neighborhood of 500K x1000x, so this would mean my KS resistance is at 500,000 ohms. Either my ohmmeter is smoking crack, or my KS is shot. 0304 (the KS code) didnt come up though. I wonder whats up.
ericdwong is offline   Reply With Quote
Old 06-10-2002, 09:59 AM   #11
Quote:
Go here:
http://www.skippynet.com/maxima/knocksensor.htm
__________________
PhatBastard is offline   Reply With Quote
Old 06-10-2002, 11:06 AM   #12
Send a message via AIM to Jamsan
whoops?
__________________
1997 Maxima Neptune Blue SE
In Regards to Nissan Service Department:
<xxxxx>Why do i bend over and constantaly take it in the *** from nissan
<xxxxx> need to replace my coil packs there gonna ask me do you want that with or without lube
Jamsan is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
