Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-18-2002, 07:40 AM   #1
Pull to the right, Pull to the left
OK...Here is the story. Got all new tires installed on my Maxima. Started driving and noticed that the car was pulling to the right a lot. I took it into Nissan and they stated that the tires needed some balancing and then told me that they corrected the pull by swapping the two front tires. Now my car pulls to the left a lot. Do I have a bad tire?
maxnewbie is offline   Reply With Quote
Old 04-18-2002, 07:47 AM   #2
You either have bad tires or Nissan switched tires that are one directional (they say one the right or left of the car).
Have your tire dealership fix the problem.
Frank
__________________
97 gle
ftb87 is offline   Reply With Quote
Old 04-18-2002, 07:56 AM   #3
Frank
When you say "directional" does it mean that the tire can only go on one particular side of the car or does it mean that it can only be mounted on the rim on one particular side?
Old 04-18-2002, 10:35 AM   #4
Send a message via AIM to dwapenyi
If your tires are H rated or below, chances are that they are omnidirectional. V,Z,W, and Y rated tires are uni-directional. You can see that by seeing a big V on the tire tread pattern. the V should be pointing up from the rear and down from the front. On regular, omni-driectional tires, you just see horizontal lines mostly. Also, on the sidewall of the uni-directional tire, there's markings saying that the tire should roll forward this --> way.
DW
dwapenyi is offline   Reply With Quote
Old 04-18-2002, 12:31 PM   #5
rmb
Quote:
DW
Speed ratings have nothing to do with tread rotational direction. True, high speed rated tires are typically unidirectional but not always. Yoko Avid T rated tires are unidirectional.
The only way to tell is to check the sidewall carefully. You will see an arrow and an indication of which way the tire should rotate if that's the case.
If they are mounted correctly you could simply have a bad tire. I've had several Dunlop 8000's in the past that pulled... They were all replaced by Dunlop for free.
Out of balance won't create a pull either... unles it's jumping off the road.
-RMB
rmb is offline   Reply With Quote
Old 04-18-2002, 01:22 PM   #6
That's why I said chances are
DW
-RMB
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
