Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-22-2002, 12:04 PM   #1
Crank Shaft Sensor Bad NEED HELP ASAP
How hard is this to change? Mine is bad and they want 380 to fix.. Where is this located yadda yadda...
HELP
__________________
<img src=http://www.rit.edu/~aps1723/gif_files/15wasted.gif>
Gumby510 is offline   Reply With Quote
Old 03-22-2002, 12:09 PM   #2
Send a message via AIM to KWheelzSB
Re: Crank Shaft Sensor Bad NEED HELP ASAP
Quote:
HELP
Crankshaft Position Sensor (?) Is that what you mean?
If so, there are actually two:
1) Crankshaft Position Sensor (REF) - it's mounted at the front of the engine, on the aluminum oil pan section below the crankshaft pulley.* Scan Tool Code: P1335 / ECU DTC: 0407
2) Crankshaft Position Sensor (POS) - it's mounted on the aluminum oilpan section at the rear of the engine near the transaxle bellhousing.* Scan Tool Code: P1336 / ECU DTC: 0905
Either is VEEEEEERY E-Z. 10 mins, tops, easily accessible.
You should first run an ECU check yourself, to determine exactly which sensor is throwing the code.
If it is the (POS) sensor that is causing trouble, (before you spend the dough on a new unit), remove the existing sensor from it's mounting seat and clean off the tip, reinstall, reset your ECU, & see if the CPS(POS) DTC is generated again. (This is the one I have experience with).
I got a CPS(POS) DTC once, and did just this: (there were fine metal particles covering the tip of the sensor [which is magnetic]) I assume these particles were confusing the readings generated by the sensor and transmitted to the ECU, which in turn, took the "bad" readings to mean that the sensor had failed & needed to be replaced.
After I did this, I never had the problem again & have had no driveability issues, whatsoever.
*Refer to Hayne's (Section 6-12)
Good luck!
P.S: If you DO need to buy a sensor, check out www.courtesyparts.com, or Tustin Nissan (don't have the url) Mention you're a maxima.org member & get a break on the price.
__________________
1995 Maxima SE (5-speed)
"A child of five could understand this. Fetch me a child of five."
-Groucho Marx
KWheelzSB is offline   Reply With Quote
Old 02-13-2008, 04:26 PM   #3
Hello,
I just signed up and cannot post a new thread, so I thought I would reply to this one and hopefully someone will read it. My wife's car has had trouble starting for a while and today it took almost an hour to get it started. I am almost positive it is the CPS, but I don't know where they are located to try and pull them out and wipe them off. I leave town tomorrow and want to try to try this so she won't get stranded or have to get it towed out of our garage.
Could anyone provide me with detailed instructions on how to find these two sensors (from which side of the car, do I need to crawl under it or can they be accessed from above, etc). I work on motorcycles quite a bit but have never done anything to a car other than change the oil.
Thank you for all of your help!
Grad is offline   Reply With Quote
Old 02-13-2008, 08:26 PM   #4
The Dirty Pearl
pmohr's Avatar
Quote:
Originally Posted by Grad View Post
Hello,
CPS is cam position sensor, not crank. In any case, CPS:
CKPS POS (follow the harness down, it's bolted right where the block and the trans meet. Actually the upper oil pan I think, but it's easily viewable):
CKPS REF (it says POS, but that's the FSM for you...):
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 02-13-2008, 09:38 PM   #5
Send a message via AIM to QNO_A32
+1 on cleaning them off first.clean all three while your at it, cam and both crank sensors. 10mm gearwrench or ratchet.also on the pos sensor which is the one that reads off the flywheel there is a thin metal piece there too about 1" by 2",the bolt that holds the sensor on goes throught it.you should clean that really good also,preferably with a wire/grinding wheel.check all of them and if still no good buy the needed part from nissan and diy.
__________________
I LOVE WEED CREW MEMBER #1
QNO_A32 is offline   Reply With Quote
Old 02-13-2008, 11:08 PM   #6
Send a message via AIM to densetsu
it can be done in less than a minute. unclipping of sensor and removal of one or two 10mm bolts is all it takes, you dont even have to jack the car or anything. 380 is a rip off its not even worth it to pay someone ten bucks its so easy to do. ask them which sensor (crank or signal plate one) and just buy the sensor and do it yourself.
densetsu is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
