Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-11-2002, 07:47 PM   #41
Send a message via AIM to NotNew!!NewSN!!
Quote:
Originally posted by NightRider
I have the Cattman Coilovers and would not recommend them to anyone. I can attest to many races won and quick turning because of the coilovers though. They will make your car handle like a formula one race car. However, they have the worse ride quality known. I've ridden and driven many Maximas with different setups. Even some without bumpstops and tokicos (not a good combination). And all have felt better and more refined than the Cattmans. Not only that, the quality of the suspension is not there. I've owned them for about a year, and already have experienced a broken front strut mount, sagging front springs, and a broken rear strut piston. There is hardly any spacing between the coils on the front springs which results in binding while driving on any roads other than a newly paved highway. Since they were cheaply made, it's impossible to dial in the correct ride height or keep your wheels aligned properly. I'm am very dissatisfied with this setup and urge others to exercise caution before selecting this suspension.
i thought cattman coils were basically done up ground controls with agx's (meaning camber crap and stuff combined into it) im gettin ground controls, anyone with the same feedback, i plan on gettin custom springs from grond control if mine are too ruff
__________________
95 SE 5 speed
I got some mods...
NotNew!!NewSN!! is offline   Reply With Quote
Old 03-20-2002, 08:03 PM   #42
4 Maximas and counting
Send a message via AIM to philpoe Send a message via Yahoo to philpoe
Re: Suspension Questions answered
At what point do you need a camber kit when lowering?
I'm currently on Eibach/Tokico, which is a bit harsh on PA roads compared to stock SE setup (it handles great though).
I got them in a set for $510 from Stillen.
I'm looking at H&R, B&G or Maxspeed for the softer spring, but the drop is lower than Eibach (except possibyl H&R?), possibly making it as harsh as before on OEM-like struts. I guess KYB AGX is the only real choice these days if I swap them out.
Any thoughts on any of the above mentioned springs with AGX?
Quote:
Originally posted by SuDZ
Springs
H&R
Drop: 1.3 – 1.5 inches
Ride Quality: Closest to the stock SE spring. They will give you a nice drop without having a very harsh ride.
Eibach
Drop 1.5 inches in the front 1.3 in the rear
Ride Quality: Comparable to H&R. The difference will be felt though. They are a harder spring then H&R.
Maxspeed
Drop: 1.7 inches in the front and 1.4 inches in the back.
Ride Quality: Almost like they were there stock SE springs.
B+G
Drop: 1.6 inches
Ride Quality: On back roads where it begins to get bumpy ride can become harsh. Smooth on flatter main/highway type roads.
Struts
KYB – AGX
Right now they are one of the most common struts for the Maxima. They have a great reputation with these struts as far as lasting without any problems. They are 8 way adjustableon the back and 4 way adjustable on the front, which means that they have 4 or 8 separate settings on them to control how firm you want them. They firmness is changeable while still on the car unlike some others where you have to remove the wheels.
Cost: Around $400.00
Tokico
These are a direct OEM replacement for your Maxima. Basicly if a strut blows you can get them rplaced with thes under warranty. They are a strut that is not made for the extra work of a big drop but a bit more aggressive than stock. Since they have that somewhat stock side to them your not going to want a very big or harsh drop on these. for more info check uot this link.
http://www.tokicogasshocks.com/car/performance.html
Cost: Still looking
SuDZ [/b]
philpoe is offline   Reply With Quote
Old 03-21-2002, 07:10 AM   #43
Send a message via AIM to dwapenyi
Re: Re: Suspension Questions answered
No, you're not on Eibach's and H&Rs
DW
Quote:
I'm currently on Eibach/H&R . . .
dwapenyi is offline   Reply With Quote
Old 03-21-2002, 10:13 AM   #44
Re: Re: Re: Suspension Questions answered
No wonder I was complaining about the ride!
Quote:
DW
Old 03-21-2002, 10:53 AM   #45
You may not need a camber kit. When my SE was stock, I put 17s on it. They wore un-evenly because they were off camber. I knew i needed an alignment, but since I was going to upgrade the suspension soon, I decided against it. When I put on my H&Rs and Toks, I immediately got an alignment done. The alignment guy told me everything was in spec, no adjustment necessary. Now, 20,000 miles later proves him right. My tires have been wearing perfectly.
So, do the suspension change without the kit. If needed, add it later.
DW
Old 03-21-2002, 01:16 PM   #46
Send a message via ICQ to SuDZ Send a message via AIM to SuDZ
DW
Is it something that is easy to add after the work of installing the new suspension has already been done?
SuDZ
__________________
'98 Se 5 Speed.
My Cardomain site for my Z
SuDZ is offline   Reply With Quote
Old 03-21-2002, 01:40 PM   #47
Re: Re: Re: Re: Suspension Questions answered
I couldn't really say, since I've never had one. I think te kit sits on the bolts, so you just add it on top, don't have to pull apart the suspension again. Hopefully someone else can clarify that.
DW
SuDZ
Old 03-21-2002, 04:24 PM   #48
Re: Re: Re: Re: Re: Suspension Questions answered
DW
I think your right cause I was looking around a bit before I asked and got the idea that is all there really was to it. I was kinda just double checking here though since nobody ever really mentioned the install process in the other threads.
SuDZ
__________________
'98 Se 5 Speed.
Old 03-21-2002, 11:30 PM   #49
What I'm hoping to find out is if I'm planning to go with a new setup and an alignment, should I get the camber kit out of the way now? If I added it later I'd pay labor and another alignment, right?
The Maxspeed springs are looking like a decent candidate as they seem to be SE stock-like, except for the large drop (possibly requiring a camber kit). combined with some AGXs, I may have found a more suitable match. Otherwise I might go with H&R and ride a little higher.
DW
Old 03-22-2002, 06:57 AM   #50
Well, the idea is that you may not even need the camber kit at all. It's a chance, you call the shots. I have H&Rs and Toks running on 17x7s and I didn't need a kit at all. As for the Maxspeed springs, I find it hard to beleive that you can have the same ride as the stock SE setup with much less suspension travel. Something's got to give. If it does indeed ride like that, then it must bottom out alot, too.
DW
Old 04-08-2002, 05:18 PM   #51
Send a message via AIM to tyrotrader
I have tokiko/eibach. The installer forgot to put on the tokiko's (only put on eibachs)- I drove home without realizing thinking it was handling better that stock, but wasn't harsh at all. Then I went back and had him put the Tokiko's on - Great handling, but harsher than I would like - good on good roads, but tough on anything thats very bumpy. I'm over 30 now, maybe if I was 18 I wouldn't care.
Paid $580 shipped at atomicautosport (maybe I got ripped - probably average for online)
tyrotrader is offline   Reply With Quote
Old 04-08-2002, 06:13 PM   #52
Wow, it has been a while since I updated this thread. I think it is time to add the following link
what does this mean
A very informative link when it comes to what else you may want to consider changing when you do your suspension. A lot of thanks to everyone one this thread that made it so helpfull. I will add it up top to my originol post as well.
SuDZ
__________________
'98 Se 5 Speed.
Old 04-09-2002, 03:19 AM   #53
Send a message via AIM to WDragonM
question on chains
When you lower your car with say H&R or Eibach or whatever, can you still put chains on easily? I have the stock 15 inch on my GLE and plan on going boarding again in the winter. Thanks.
__________________
97 GLE Automagic
Mods: Stillen FTSB, Addco RSB, Clear/Red Tails, Diamond Clear Corners, shaved corner lights, Amsoil Series 2000 0W30 Oil and Mobil 1 Synth ATF fluid, polargs in the front and corners, Bridgestone Potenza RE950, Catz fog lights, Porterfield R4S brakes, Nissan OEM fronts, and a Broadway Optics Rearview...
WDragonM is offline   Reply With Quote
Old 04-09-2002, 10:26 AM   #54
Re: question on chains
Quote:
Do you mean like the type of chains you wrap aropund the tires? I am just checking because here it is illegal so I dont know if you mean something else. If that is what you mean how high off the tires do the chains come? This will help figure out how much space you need or will have.
SuDZ
__________________
'98 Se 5 Speed.
Old 04-09-2002, 12:40 PM   #55
Send a message via ICQ to Brendan98GT Send a message via AIM to Brendan98GT
so whats gonna happen when i put my new maxspeeds in my 43k mile 98 I30 without replacing anything else?
__________________
2001 Infiniti I30 Touring - PICS
• Clear Side Markers
• In-Dash DVD
• JL Audio 500/1 amp
• 2 JL Audio 12W3v2-D2 subs
OLD CAR:
1999 INFINITI I30 Touring - PICS
• MaxSpeeds
• FSTB
• Dunlop SP5000 235/45/17's
www.WeDontDrink.com
Brendan98GT is offline   Reply With Quote
Old 04-09-2002, 01:07 PM   #56
Quote:
Some people find that they may need a suspension. Some people find a bit more noise. It is recommended that you at least check other components to make sure nothing will lead you to take the suspension apart at some other time to do repairs. It cant hurt.
SuDZ
__________________
'98 Se 5 Speed.
Old 04-09-2002, 03:38 PM   #57
Bump!
Excellent thread suDZ!
Can you say stickie? or is it sticky? whatever, why isn't it up top??!!
__________________
Sold - 1997 SE, Black on Black, All Options.
Tokico, Eibach, Gewalt Type S, Bridgestone S-03, PIAA, Tenzo, Courtesy Nissan, Ram Air Charger, Cattman, JWT, A'PEXi, Random Technology
Driving - 99 Mercedes-Benz CLK 430
Slammed with Carlsson's and too much more to list..
Str8ridin is offline   Reply With Quote
Old 04-09-2002, 03:50 PM   #58
Quote:
I would say it's not a sticky because people can still search! I'm all for stickies, but we need a sticky forum or something. Granted there aren't too many stickies, but the more there are the less room there is for normal posts. As it stands many good posts are skipped in favor of redundant intake/bulb/suspension questions so why make it worse
-hype
__________________
for the uneducated, when they engage in argument about anything give no thought to the truth about the subject of discussion but are only eager that those present will accept the position they have set forth-Plato
xHypex is offline   Reply With Quote
Old 04-09-2002, 03:51 PM   #59
Bump!
Thanks, I actually created it maybe a month or two ago if you look at the dates. There is one that is basicly the same idea but regarding Exhaust components around here somewhere that I made the day after this one. Glad you found some use for it.
SuDZ
__________________
'98 Se 5 Speed.
Old 04-09-2002, 04:12 PM   #60
Re: Re: question on chains
Yeah, the chains that wrap around the tires. I have cables though (look like springs wrapped around cables, instead of actual chains). I did a search and found that people in snowy areas recommended having coilovers like ground control, but I wasn't exactly sure why because it seems like the chains will still fit with the drop. I don't have a body kit and I don't plan on getting one anytime soon so I was wondering if there was some other issue that might make coilovers preferable to regular springs in snowy conditions.
SuDZ
__________________
97 GLE Automagic
Old 04-09-2002, 04:18 PM   #61
Re: Re: Re: question on chains
Well the main reason people may have wanted to haev the coilvers is because if snow happens to come then you can aise the car back up to stock height within about 10 minutes or so. Some people feel safer and more comfortable at that height when conditions are bad. That is just their personal opinoin.
As far as the chains having enough room you have to figure it this way, inside the fender goes up higher than you will see from the outside, this gives you enough room to run the cables without having too many issues or any at all. I mean they are not going to be moer than 3 inches thick right? That is about how much room you will have in there. Also if your using a stock sized tire, which during the winter I would assume yes, then there should really be no clearence issues.
SuDZ
__________________
'98 Se 5 Speed.
Old 08-03-2002, 11:59 AM   #62
Send a message via AIM to iregula
nice write up!
iregula is offline   Reply With Quote
Old 08-04-2002, 07:51 PM   #63
Quote:
Originally posted by iregula
nice write up!
SuDZ
__________________
'98 Se 5 Speed.
Old 08-06-2002, 05:57 PM   #64
Re: Thanks SUDZ
Quote:
Originally posted by dlicari
maxspeed springs can be picked up on a group deal for under $100 dollars. I will let you know the drop after I install tomorrow.
BigDog Jonx gor 1.7 and 1.4 from them.
Where can i find this group deal?
magnum658 is offline   Reply With Quote
Old 08-06-2002, 07:09 PM   #65
Send a message via AIM to 97GLE Send a message via MSN to 97GLE Send a message via Yahoo to 97GLE
Re: Re: Thanks SUDZ
Quote:
In the group deals section
Lights Out Help!
97GLE is offline   Reply With Quote
Old 08-06-2002, 08:31 PM   #66
SuDZ
If i get maxpeed springs or any other springs or coilover will i be ok with my stock struts or will i need to get new ones?
Old 08-07-2002, 02:53 PM   #67
Your questions can be answered with a search. Use it.
A drop will put more stress on your shocks and likely cause premature failure, also your ride will likely have exagerated rebound with short springs and soft shocks. However, many people still use their stock shocks until they have the cash to get a good set of aftermarket shock/struts. I think doing this with coilovers or a drop over 1.7in would be a mistake, but if your on a budget, using less aggresive springs(ie, maxspeed, h&r...) and dont mind tearing your suspension apart twice for springs and shocks then you can do it.
Old 08-07-2002, 04:27 PM   #68
Also if you are paying someone to do it for you, you will end up paying them twice.
SuDZ
__________________
'98 Se 5 Speed.
Old 08-18-2002, 08:04 AM   #69
Send a message via AIM to A-RokI30T
If you guys had a 98 I30T and you were putting 18" wheels on it but also wanted to lower it, would you go Eibachs? Intrax? or H&Rs? To be able to get that even drop since the back sits a little lower than the front. I live in Massachusetts and the roads here can get a little bumpy, so I wouldn't want something that will give a very harsh ride on not so smooth roads. Tell me what you think.
A-RokI30T is offline   Reply With Quote
Old 08-18-2002, 08:19 AM   #70
Send a message via ICQ to Lime Send a message via AIM to Lime Send a message via Yahoo to Lime
awesome, SUDZ! Can I use that info for my NEMAXIMA site too? :} I will be putting together a how-to with lots of pictures shortly.
__________________
erica
1998 maxima SOLD
1985 Toyota MR2
1988 Nissan Pulsar NX SE
car pix
Lime is offline   Reply With Quote
Old 08-18-2002, 05:45 PM   #71
A-RokI30T, I am in Massachusetts as well. Now you said your looking for a harsh ride on not so smooth roads? I am wondering if you did this a bit off and are asking for a not so harsh ride on massachusetts roads ? If so then you might want to consider the H&R's only because they have a nice smooth ride to them that will feel almost like stock as far as how hard they hit bumps. I have ridden in a few cars with them and they are very easy to get along with, as compared to cars where you feel every little touch in the road. Plus they wwill still have a noticeable drop that will reduce the wheel wells nicely.
SuDZ
__________________
'98 Se 5 Speed.
Old 08-18-2002, 05:49 PM   #72
Lime- Sure you can. I put it together a while ago. I think It is also under the FAQ section of Maxima Forum.
Thanks for the compliment.
SuDZ
__________________
'98 Se 5 Speed.
Old 08-18-2002, 10:14 PM   #73
SuDZ
SuDZ, sorry, what I meant to say is that I would like a somewhat smooth ride because i live In Massachusetts and the streets in my area are horrible. but i'm willing to sacrifice a little harshness if i can get a nice even drop front and back. I'm putting 18x8.5s on my I30T so i'm not looking for a 2" or even lower drop, just something that will give it a sweet look, but most of all an even drop. somewhere between 1.5 - 1.7" in the front and maybe 1.4 - 1.5" in the back. money is not an issue, because i'm looking more for quality, but with all these choices i just can't make up my mind, and there are not too many pictures that i can look at with various lowering springs to see how the maxima/i30 sits on them. Any info that can simplify my decision will be great. Let me know what you think SuDZ or any of you guys. Thanks
Old 08-19-2002, 12:18 AM   #74
Quote:
Well I can tell you I live in Massachusetts as well and ride with the MaxSpeed springs. They are a cheaper in price but as far as quality goes they are excellent. I have had them on for a few months now and they still ride nice and firm and do look nice. I have stock rims for now but the way it eliminates the wheel well is excellent. Very noticeable drop that makes the ride look better seated while not being overly harsh when driving. I do feel it a bit more when I hit a harder bump but not much more than stock.
I dont know where you live but in Lowell where I am the road conditions bascily range from smoother paved areas to potholes large enough to lose a civic in to roads that are still old cobblestones downtown to combinations of them all. It is a tough town on suspension but the maxspeeds have help up well against it. I would recommend them again to someone intrested in buying springs in our area.
SuDZ
__________________
'98 Se 5 Speed.
Old 08-19-2002, 12:21 AM   #75
Send a message via AIM to MaxedOut
SuDZ
i have eibachas and i dive thru worcester all the time... eibachs are wayyy harsh.. but the drop is beautiful... and it might be extra harsh on my car.. cuz right now all my shocks are blown...
__________________
Proud Brother of the University of Massachusetts at Amherst, Xi Chapter, of the Pi Delta Psi Fraternity Inc., the fastest growing Asian Interest Fraternity
Gone:
1995 Green Nissan Maxima GLE
2003 Blue Nissan Maxima SE 6 Speed (Totaled)
2002 Black Nissan Maxima SE 6 Speed (engine Oil problem)
Now:
2005 Infiniti FX45 -- Fully Loaded
MaxedOut is offline   Reply With Quote
Old 08-19-2002, 12:26 AM   #76
Quote:
What kind of struts were you running on you car?
SuDZ
__________________
'98 Se 5 Speed.
Old 12-23-2002, 03:52 AM   #77
Playboycutie69
springs stiffness
Does stiffer springs mean better handling and cornering? Or does it just mean that u feel the bumps better? Because I seen drops eibach and a few others and I think the max looks better as low as it can be(because it is so damn high to begin with), This makes me think thte best thing for me going for the look I want is getting Sprint springs with the agxs. Then with the 18's I plan on getting that **** shoot look crazy sweet.
Old 02-19-2003, 10:34 AM   #78
Try to keep the thread on topic guys. I dont want this one to run away since it has a lot of good input.
SuDZ
Clee - stupid posts were deleted.
__________________
'98 Se 5 Speed.
Old 03-17-2003, 06:56 AM   #79
Beast Mode!!!
Send a message via AIM to skuccio's max
bump bump bump
Why doesnt someone sticky this up?
-95SE
__________________
skuccio's max is offline   Reply With Quote
Old 03-17-2003, 07:42 AM   #80
Do the Motivational Engineering front struts and rear mounts deserve mention in here?
Lately there have been tons of suspension questions coming up regarding things like coilovers, struts, springs, etc. I thought that maybe we could throw something together as a type of guide. I know that this will not be answering all of the questions out there or that this is the most definitive guide but it cant hurt. If anyone has anything that they can add to this for me then as you show me more info I will change it here. I don’t know if this thread will just die but might be helpful one day to people who are searching for info.
<snip>
SuDZ
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
