4th gen springs questions
Old 02-27-2002, 09:34 AM
spamman's Avatar
OK, i have a 97SE and here are my questions:
1) With the SE package, what is the "sport" suspension? Spring rates?...etc?
2) Do the Maximas benefit from progressive rate springs for handling and ride?
3) Are most of the Low cost lowering springs out there specific rate?
4) Wasn't there a brand of springs from "B&G"? Any insight on these?
Thanks all: e3 - spamman
spamman is offline
Old 02-27-2002, 01:40 PM
SuDZ's Avatar
Re: 4th gen springs questions
1. Yep, stiffer springs.
2. You mean like upgrading the springs for better handling? Yes. Along with some good struts.
3. You might wanna look on the sites on those companies for the rates, they would have better info.
4. Yeah there still are. Depending on what kind of ride your looking for these are softer that some other companies.
SuDZ
SuDZ is offline
Old 02-27-2002, 02:23 PM
Minister of Silly Walks
mzmtg's Avatar
Specific spring rates are often considered proprietary and not widely avaiable from most aftermarket companies.
mzmtg is offline
Old 02-27-2002, 05:27 PM
spamman's Avatar
Re: Re: 4th gen springs questions
SuDZ
Sudz:
Thanks for the reply.
1) So the stock ones are stiffer, but are they specific or progressive?
2) What I meant was, do the maximas work better with specific or progressive?
3) Thanks.
4) I have heard of them and also found a set of new springs in a magazine, hot compact and import, for like 119$ for all 4.....
Peace: e3 - spamman
spamman is offline
Old 02-27-2002, 06:36 PM
chris j vurnis's Avatar
hello:
The GXE model uses 200LB/IN springs at all 4 corners. These are linear rate springs.
The SE model uses 250LB/IN springs at all 4 corners. These are linear rate.
Eibach pro-kits are 150-250LB/IN progressive in the front and
150LB-350LB/IN progressive in the rear.
I don't know the H&R spring rates...
I called them today and they didn't give me the information.
But anybody with a spring tester can find out that information and pass it on to the whole world via the Internet. So I don't see why it would be proprietary information.
later..
chris j vurnis is offline
Old 02-27-2002, 07:17 PM
NightRider's Avatar
Originally posted by chris j vurnis
hello:
later..
Dude, you are way wrong. GXE spring rates are 112 lb/in. and SE spring rates are 134 lb/in. Linear rate. Most lowering spring manufacturers vary around the 175/300 lb. Progressive rate. BTW stock M3 springs are 174/263 Progressive rate.
NightRider is offline
Matt93SE
05-24-2019 02:58 PM
Maxima_Joe
11-25-2015 08:19 AM
Finkle
09-27-2015 09:53 PM
ViciousVQ30
08-05-2015 05:40 PM
Quick Reply: 4th gen springs questions
