Rebuilt the control arms with ES and Moog
I'm nutty for Nissans
I took the hardest path and rebuilt the original LCAs. I hope this combination lasts and I never have to do that again.
Moog made in Japan ball joint
Moog front bushing
Energy Suspension rear bushing
Trashed, it fell apart.
Other side needed more effort to remove.
Front ES bushing new compared to used (off my old car). It didn't last so i did not use ES front bushings.
Pressing out the BJ on a spare control arm, rear pivot ended up being junk.
Pressing out front bushing.
New parts I used. Moog front bushing, BJ, ES rear bushing.
Pressing in the new.
After all the work, cleaned up and painted.
Moog front bushing
Impressive JS! Wish I had a garage so I could invest in a press. Looks like the Harbor Freight 20 ton? But this is a 12 ton?
After Moog discontinued their Problem Solver line of Control Arms for 4th Gens, you did the only thing that should net years of solid reliable performance. Everything else available now is sub par.
Can you feel a difference with the ES bushings? Some say it's a bit more unforgiving and that transfers to your teeth on rough roads. LOL The Moog Ball Joint with the grease fitting is still the best choice.
Nice work!
Nice work!
It's a 12 ton, barely big enough to get the control arm situated to get the front bushing out. It was given to me so I am not going to complain. It's rather small and doesn't take too much space.
That's what I was worried about. Rockauto has all kinds of LCAs available. I just don't trust them after reading horror stories about them.
It's still on jack stands. I'll find out later.
Nice work!
Nice work!
I had to order multiple times to get a matching pair.
Customer return? Looks like a cheap brand, not Moog.
Made in Japan.
Made in Korea.
Made in USA.
JS, When you try to push up that bushing into the cavity recessed into the bottom of the car, Lube it up with some water based FUN lube.
And it will still be a struggle. LOL Like a Madonna song! Touched for the very first time.
Can't believe the Ball Joints all had the same part number! Hello! Do these even look alike?
The Moog CK line of Lower Control Arm assemblies were unfortunately discontinued years ago. They only have the RK value line of LCA assemblies and they aren't even close to the strength of the CK line. I can believe these could crack with a deep pot hole.
And why JS rebuilt his! Smart..... Very Smart!
Lol. Philly is not kind in many ways. I had another buddy with the same type of LCA failure on a different aftermarket part which prompted me to get those CKs.
The roads are one of the reasons I ran slightly oversized tires on 18s 255/50/18 and 245/45/18.
As for solid poly bushings adding harshness or vibrations, sure do. I have ES engine mounts, those things transmit vibration l like crazy. I also have Koni and Eibach suspension so ultimate comfort is out of the question anyway. A short test drive felt fine and steering is much better over the worn out POS bushings.
dgeesaman
12-24-2004 12:41 AM
