Spark plug tube seal part #
Old 03-10-2020, 06:42 PM
98 i30t 5spd's Avatar
I was looking up spark plug tube seals and came up with two different part numbers. 13276-31U1A and 13276-31U21. Different prices also. Both are tube seals, and both will supposedly work. Anybody have an idea to which one is correct?
98 i30t 5spd is offline
Old 03-10-2020, 06:49 PM
JvG
JvG's Avatar
They are part of the Fel-Pro valve cover gasket set.
If I remember correctly.
JvG is offline
Old 03-10-2020, 06:56 PM
Correct, they are part of the Fel-Pro set. I was just curious to why the OEM set has two part numbers and two different prices for tube seals?
Old 03-10-2020, 08:15 PM
JvG
JvG's Avatar
Sometimes manufacturers have updated parts with a different rubber type. For example the early 2000s Toyota Corola has a intake manifold gasket which likes to leak air when it gets old. They still sell the iffy gasket for a lowish price , and the proper updated gasket at a higher price..
I suppose the low price one works for a quick flip or for a car one wants to sell soon. Some people want to pay as little as possible, others pay more up front so they never need to do the project over.
JvG is offline
Old 03-10-2020, 09:35 PM
maximaxi's Avatar
They tube seals are included with the valve cover gaskets
Get Mahle VS50290
It may be under the name Mahle or Victor Reinz, but they are the same reboxed OE gaskets and seals
FWIW, the tube seals included with the Mahle/Victor set look like the 31U21. The main advantage is that it's easier to tell which way to install it.
Here is the 31U21:
Amazon has good pictures of the
13276-31U1A 13276-31U1A
You will see with the 31U1A that both sides look similar. With the other seal, one side is completely flat
Also see this earlier thread from a few years ago. The way I had it was wrong, which should've been obvious by the shape of the seals, but all the other how-to's I could find at the time looked like (the wrong way), which may be due to the seals included with other valve cover gaskets, or perhaps the different part numbers you bring up. I used the Mahle valve cover gasket set, which was called Victor Reinz at the time
maximaxi is offline
Old 03-11-2020, 12:27 PM
Get Mahle VS50290
AutoZone carries both the Fel-Pro set and the Mahle set. I don’t need it yet but I might pick one up just to have it near by. Thanks guys.
Old 03-11-2020, 02:00 PM
Maxima 97 SE's Avatar
The two part numbers matter because one of them is for the front valve cover and the other is for rear valve cover.
Maxima 97 SE is offline
Old 03-11-2020, 02:14 PM
Really? The front valve cover uses different tube seals from the rear valve cover?
Old 03-11-2020, 03:25 PM
maximaxi's Avatar
All 6 of them were the same in the package I got when I did it
maximaxi is offline
Old 03-12-2020, 10:47 PM
Yup there supposed to be different. Here are the images taken by part number and it states Quantity of 3 for each part number.
Old 03-13-2020, 12:52 AM
On Infinitipartsdeal, it states quantity of 6 for each part number, giving you 12 tube seals. And if they were truly different from front to rear, they both would not turn (yellow) highlighted when you click on one of them. I believe JvG is right when he said it’s an updated part with the old one still being available for sale.
Old 03-13-2020, 05:38 PM
JvG
JvG's Avatar
I believe I used the Fel-Pro kit when I did my valve covers. The kit came with all I needed.
I didn't over think things.
I've learned to trust Fel-Pro.
JvG is offline
TimberJon
07-08-2007 04:01 PM
Maxi98se
06-19-2006 07:48 AM
sky jumper
35
08-29-2005 02:18 PM
libo74
01-12-2005 09:02 PM
Quick Reply: Spark plug tube seal part #
