Mode selector doesn't work on my climate control.
Old 11-23-2018, 10:02 AM
evintho's Avatar
'99 Maxima GLE. The icons light up when I tap the mode selector (feet, defrost, dash, etc) but air only blows through the dash vents, not the foot vents, defroster or any combination. In addition, the dedicated defroster selector doesn't work either. However, everything else works (air recirculation, ambient temp, temp adjustment and fan adjustment). Sucks not having a defroster in the dead of winter! Is the blend door in the heater box electrically activated or vacuum activated? Don't really want to pull the entire heater box! I can get a used, working climate control module for $80 but hate to spend the money only to find out that's not the problem.
BTW, the digital clock works sporadically also. Any ideas/suggestions are greatly appreciated!
evintho is offline
Old 11-23-2018, 10:52 AM
Rit
Rit's Avatar
If you look in the FSM, you can see and follow as prescribed set of button presses that will put the heater control panel into diagnostic mode. It will tell you the exact problem.
Rit is offline
Old 11-23-2018, 02:42 PM
Violator's Avatar
You're looking for the HA section of the FSM. http://boredmder.com/FSMs/Nissan/Maxima/1998/
Violator is offline
Old 11-24-2018, 08:35 AM
KP11520's Avatar
Same situation a few years back! Bought a Mode Door Motor from an online Nissan dealer. Fixed! PITA getting under the driver's side and swapping it out though. Be prepared!
https://maxima.org/forums/4th-genera...lp-needed.html
KP11520 is offline
Old 11-24-2018, 04:43 PM
evintho's Avatar
Thanks for all the replies! Ran the diagnostic and it looks like the mode door motor is the culprit. KP11520......nice little write-up! It shows me exactly where it is and how to R&R. Many thanks on that! I'll probably pull the drivers seat to give myself some more room. I found one online for around $70. I'll order it up next week and see what happens!
evintho is offline
Old 11-25-2018, 04:21 AM
CS_AR's Avatar
Thank you KP11520. This thread will come in handy.
CS_AR is offline
QuakerJ
01-17-2019 01:22 PM
JC316
28
04-09-2013 03:26 AM
S Cranaw
01-09-2010 03:09 AM
snowboi1289
07-06-2009 04:13 PM
2maximas
01-27-2006 08:43 AM
Quick Reply: Mode selector doesn't work on my climate control.
