My Maxima is still overheating
Old 04-11-2017, 09:40 PM
Raindance's Avatar
I just changed the thermostat and the radiator and got a new cap but for some reason the engine is still overheating...what could be the problem and is there a temperature regulation button to adjust the temp???
Raindance is offline
Old 04-12-2017, 05:45 AM
Quinton Ray Fussell's Avatar
how quickly does it over heat?
Quinton Ray Fussell is offline
Old 04-12-2017, 08:09 AM
After you finished installing the radiator and thermostat, did you burp the system of air properly?
Are your fans functional and coming on?
Need more info.
The Wizard is offline
Old 04-12-2017, 12:54 PM
Raindance's Avatar
The fans are functioning and it's over heating as soon as I drive about a mile or so..how do I burp the system
Old 04-12-2017, 01:51 PM
DBear's Avatar
Sounds like a thermostat issue. Are you sure you put it in the right way? If so, it might be bad.
DBear is offline
Old 04-12-2017, 01:58 PM
Raindance's Avatar
Yes I'm sure. Tested the thermostat
Old 04-12-2017, 02:11 PM
JvG
JvG's Avatar
You should try to burp air fom the cooling system.
Raise the front of the car . Like on ramps or jack stands. Remove radiator cap. From the radiator. Not from the coolant tank.
Run the engine for 1/2 to 1 hour. Blip the throttle one in a while. Confirm that the fans turn on from time to time.
I think that if there is an air bubble right where the engine coolant sensor is, it won't turn the fans on as often as it should.
JvG is offline
Old 04-12-2017, 06:13 PM
Raindance's Avatar
I'm not able to run the car for more than 15 minutes before it starts to overheat...the fans Are all working as well and the thermostat is on correctly..so what could it be..
Old 04-12-2017, 08:45 PM
Gotta start with the free and easy stuff. Burp the system of air as directed. Report back.
Did you OEM thermostat or aftermarket?
Old 04-13-2017, 05:30 AM
Raindance's Avatar
Yes ok gonna try to burp the system
Old 04-14-2017, 08:58 PM
Raindance's Avatar
ok guys been racking my brain and break my nails where the heck is the bleeder valve located where do I find it..
Old 04-14-2017, 08:59 PM
Raindance's Avatar
it's 99 maxima se
Old 04-15-2017, 04:31 AM
KH3 by popular demand
maxgtr2000's Avatar
Just raise the front of the car on a ramp or incline let it run. Shut it off, let it cool down. Add more coolant. Do this a few times and it should be good. The radiator only has the top cap and bottom drain valve. When the car cools just remove the cap and add antifreeze.
maxgtr2000 is offline
Old 04-15-2017, 11:27 AM
Wowzers. Please follow the directions as posted. Our Max does not have a bleeder valve.
You are making this a lot harder than it needs to be.
Old 04-15-2017, 04:03 PM
allmazda's Avatar
Start from the beginning...
What was the reason you changed your radiator and thermostat?
Did the car overheat prior to changing the radiator?
Is your oil brown?
Does the car stumble/misfire when you first start it?
allmazda is offline
Old 04-20-2017, 02:52 PM
YoU CaNt SeE mE
Maxima-4DSC's Avatar
is the system building pressure. have you checked the water pump.
Maxima-4DSC is offline
Old 04-21-2017, 01:59 PM
M in KC's Avatar
Go buy a non-contact infra-red temp gun from Harbor Freight and shoot several points on the block with it running and up to operating temp. The first area would be the t-stat housing. The gun won't lie regarding temps. Could you have a bad sending unit?
M in KC is offline
