1997 Maxima Hesitating.
Take off your intake starting from your airbox all the way to the throttle body and clean everything with brushes and intake cleaner. This is very easy. Takes me about 30 mins to take off, clean thoroughly and reattatch everything. Next you'll want to change out the spark plugs which is easy but a little more involved.
some links for you:
Full intake/egr cleaning
https://maxima.org/forums/4th-genera...g-dummies.html
note: If you do not have an egr code, I would not worry about the egr tube at this time, maybe clean the sensor going into the tube.
Spark plug replacement:
Note: Anything ngk are good for plugs. I (and lots of others) use ngk coppers becuase they are cheap and perform well.
Be careful regarding what you spray in the throttle body. I've never heard of spraying b 12 in there.
The throttle body has a Teflon coating inside it. Harsh chemicals can harm that.
CRC corp makes two good chemicals which are intended for this purpose. One is called Throttle Body Cleaner.
The other one is called Mass Airflow Sensor Cleaner.
Both are sprays.
The maf cleaner might help solve this.
Both are sprays.
For sure clean the intake system as has been suggested. But even after all that my symptoms were similar to yours with no CEL lit. Driveability was terrible to the point of almost unsafe. My issues ended up being the intake air temperature sensor and the MAF itself.
bbsitum
02-20-2016 12:05 PM
CAN-Toronto WTB: 2002-2003 OEM Car Cover
Will
02-16-2016 04:17 PM
