Please recommend low cost MAF
Old 02-04-2016, 03:17 PM
gallilaw's Avatar
I bought an EBay MAF about five years ago and got somewhat lucky because it lasted that long. The dealer is no longer to be found.
Please recommend a specific source for a MAF, based on your personal experience that the MAF from the dealer actually works.
Thanks!
gallilaw is offline
Old 02-04-2016, 04:25 PM
PH98I30's Avatar
My best source for a good OEM MAF is a wrecking yard. I have had good results there.
PH98I30 is offline
Old 02-04-2016, 04:40 PM
Maxima 97 SE's Avatar
Buy the new updated version of the MAF sensor from ebay. It doesnt have those problems like the original did because I bet they probably fixed them. Also this maf originally came with nissan skyline. 22680 31U05 A36-608 E61. If your gonna buy a maf only buy original otherwise it will not work and you will have issues. The model number I gave you is the new updated version of the maf sensor and what the dealer sells for 500.00. On ebay its selling for 99.00. Dont buy the 22680 31U00 A36-608 E60 model as that is the older model that comes with originally with our cars and has issues.
Maxima 97 SE is offline
Old 02-04-2016, 07:08 PM
IMO, this is your best bet. or post a WTB in the classifieds.
The Wizard is offline
Old 02-04-2016, 07:10 PM
LJay's Avatar
Or you could order an OEM one on eBay for about $30. Worked perfectly for me
LJay is offline
Old 02-04-2016, 09:40 PM
maximaxi's Avatar
The only ones worth buying are Bosch and Beck/Arnley.
Bosch part #63128, will likely run $150-200. It's a reboxed OEM MAF. I wouldn't buy one from the junkyard since MAF failure is common on these cars. I don't like to buy common failure items at the junkyard.
I bought a Bosch on Rock Auto, and it's fantastic. Made in Japan.
maximaxi is offline
Old 02-05-2016, 08:35 AM
gallilaw's Avatar
LJay or anyone else:
Please provide more information about the OEM MAF you bought, that actually worked.
Seller?
Link?
Thanks!
gallilaw is offline
Old 02-05-2016, 09:28 AM
dot dot dot ...
NmexMAX's Avatar
Bought one for 35$ back in 2004, been running fine ever since.
NmexMAX is offline
Old 02-05-2016, 11:34 AM
MadManMax-M3's Avatar
Like what others have already suggested, I think you would want to get a MAF from a local junk yard. I have had experience with a brand new aftermarket MAF. While it did help to correct my issues at the time, the car didn't run as well IMHO as when I purchased a used OEM MAF from the junkyard.
The only concern I would raise though, if you can find the number to the junk yard maybe you may want to give them a call first before traveling out there if it is out of the way. This way they could help you to identify if they any MAFs in stock or if they recently got 4th gen Maximas in. I say this because usually the MAFs is one of the first goodies to go in a pull-it-yourself junkyard. Good luck!
MadManMax-M3 is offline
Old 02-05-2016, 11:51 AM
dot dot dot ...
NmexMAX's Avatar
I had mine shipped from www.car-part.com
NmexMAX is offline
Old 02-05-2016, 01:41 PM
jerrod99_se-l's Avatar
The only concern I would raise though, if you can find the number to the junk yard maybe you may want to give them a call first before traveling out there if it is out of the way. This way they could help you to identify if they any MAFs in stock or if they recently got 4th gen Maximas in. I say this because usually the MAFs is one of the first goodies to go in a pull-it-yourself juonkyard. Good luck!
i have 2 in the local pick and pull at my disposal...whenever I want them...make that 3...forgot about the I30 too
jerrod99_se-l is offline
Old 02-11-2016, 06:33 AM
coskuntarik's Avatar
I just bought Dorman brand like a few months ago, it works great and there is no code with obd scanner. it cost 120 bucks
coskuntarik is offline
Old 02-11-2016, 03:22 PM
slickblack94's Avatar
I just saw a good Used OEM on the auction site........ I bought a cheap one off there and it worked great.
slickblack94 is offline
Old 02-11-2016, 09:19 PM
LJay's Avatar
I searched on eBay "(insert Maxima year here) Nissan Maxima oem mass air flow. I have a 1999 & this is what I found http://www.ebay.com/itm/95-96-97-98-...BV04to&vxp=mtr
http://www.ebay.com/itm/22680-31U00-...5WbKuB&vxp=mtr
LJay is offline
Old 02-12-2016, 12:41 AM
BronxSleeperMax187's Avatar
Tried the Ebay one once recently.....died same day....lucky I had my old one that still worked but for 30 bucks why not try A new one and keep it as A reserve just incase that day comes again.....big waste of $$$ and learned my lesson......when I changed my first MAF I used the Autozone updated one and they price matched it for me (nice manager)with Rock autos price that I printed and bought as proof to em....saved 70$$ back in the day as it was like 140 .....now its the same price anyway.....still need A reserve.....so them ebay ones are hit or miss IMO.
BronxSleeperMax187 is offline
Old 02-12-2016, 04:35 AM
max ride 41's Avatar
am i the only one with their original 285,000 mile 21 y/o maf still in their car??
max ride 41 is offline
Old 02-12-2016, 09:54 AM
JvG
JvG's Avatar
Good for you, Maxride 41.
Shows how long junkyard mafs might last.
JvG is offline
Old 02-12-2016, 11:26 AM
Mine has 443,000 miles on it..it has a oem maf on it...not sure if it's original or not
Old 02-12-2016, 06:03 PM
truly, mine ie original and probably should be replaced at some point.
Old 02-12-2016, 09:51 PM
Ptatohed has the same mileage as you. Original MAF.
I'm at 235k, and supercharged with original MAF on my DD...still kickin'.
Maximam
05-03-2016 08:27 PM
slpgh
01-27-2016 10:15 AM
03Alt3.5Biz
01-21-2016 06:44 PM
kirkhilles
01-21-2016 03:28 PM
spy code1
01-05-2016 03:27 PM
Quick Reply: Please recommend low cost MAF
