1997 Maxima SE Auto
Old 11-24-2015, 04:41 PM
bassmann's Avatar
1997 Maxima SE Auto
Hi, the car starts up,but when I put it in drive it stalls. The car will not drive. Has anyone had this problem? Please help if you can.
bassmann is offline
Old 11-24-2015, 05:22 PM
jerrod99_se-l's Avatar
Have u checked for codes? Start there
jerrod99_se-l is offline
Old 11-24-2015, 06:01 PM
bassmann's Avatar
Engine light isn't on. Can I still get a code?
bassmann is offline
Old 11-24-2015, 06:26 PM
JvG
JvG's Avatar
You either have a vacuum leak, or more likely an issue with the iacv. Intake air control valve. This device allows air into the engine for idling. If it malfunctions, your car will be hard to start when cold, but may idle normally when warm. Has the place you live gotten cold? Did your car idle normally a month or two ago?
JvG is offline
Old 11-24-2015, 07:28 PM
bassmann's Avatar
Yes it got cold last night. Yes car was fine before it got cold.
bassmann is offline
Old 11-24-2015, 09:05 PM
DennisMik's Avatar
Can you keep the engine running long enough for the engine to warm up? And if you can, does the problem seem to go away?
DennisMik is offline
Old 11-26-2015, 08:49 AM
bassmann's Avatar
I will try. Thanks for your help men.
bassmann is offline
Old 11-26-2015, 11:39 AM
Maxima 97 SE's Avatar
Could be bad mass air flow sensor. Try to unplug the sensor and see if it stays running and if it does then it's a bad maf. Also a bad maf will usually stall the car while driving or stall while its in drive at least that's what happened to my Nissan Maxima 97 se.
Maxima 97 SE is offline
Old 11-28-2015, 12:36 PM
JvG
JvG's Avatar
If it's temperature sensitive, it's the iacv. That's it's job.
It can be removed, cleaned, reinstalled. Instructions are available in the search section. Been there, done that.
JvG is offline
Old 12-01-2015, 02:59 PM
bassmann's Avatar
it drove fine today when i started it in the late afternoon. when i start it in the morning it idles fine but when i put it in drive it stalls. weird.
bassmann is offline
Old 12-01-2015, 10:16 PM
DennisMik's Avatar
How cold is it in the morning where you are? A bad ECTS that reports a false high temperature when cold will cause a lean fuel mixture, which is the exact opposite od what a cold engine needs.
When the engine is cold and not running, unplug the wire harness and measure the resistance of the ECTS. At 50º F (10º C) the resistance should be around 4K ohms. At 70º F (21º C) about 3.5K ohm. At 195º F (90º C) it should read about 250 ohms.
Old 12-02-2015, 08:45 AM
Quickywd01's Avatar
Unfortunately I had this happen on my 99 se auto. Had only 50k miles. Was clean as new. I cleaned the iacv, it was clean like new. Look into the drop resistor, it might be causing issues. I had to rev it in neutral just high enough to get out of the driveway. The car also drove like it was stuck in high gear. Eventually a diff pin popped out thru the case. Still drove home fine. I have pics in my album and SC thread. I bought a newly rebuilt trans, LMK if you need one. Also have an old one from my current car that's not rebuilt but it drives perefct like the rebuilt one.
Quickywd01 is offline
Old 12-02-2015, 12:41 PM
bassmann's Avatar
Im in CT. It was between 30 and 35 degrees when this started. It was around 50 yesterday with no problems. Thanks for your help.
bassmann is offline
bassmann's Avatar
bassmann is offline
rbarnes
12-28-2015 04:32 AM
bnotty05
12-10-2015 11:47 AM
Tequila
12-06-2015 08:29 PM
JM AUTO RACING
11-30-2015 07:20 AM
spidgeon
11-05-2015 04:08 PM
Quick Reply: 1997 Maxima SE Auto
