Outer CV boot torn.
Old 02-20-2015, 12:18 AM
asand1's Avatar
I discovered a torn boot on my passenger side outer joint yesterday.
asand1 is offline
Old 02-20-2015, 01:16 AM
dwapenyi's Avatar
Has the axle started clicking yet? If not, you could just seal it up and fill it with grease. Depending on how soon after the initial break you had found the tear, you could be buying a couple of months to even years more axle life before failure.
Also, that Pennzoil Synchromesh doesn't seem to specify whether its GL-4 or not.
dwapenyi is offline
Old 02-20-2015, 01:23 AM
asand1's Avatar
No clicking yet, I caught it early. I do plan on just replacing the boot. The axle is less than 2 years old.
Gl4 only applies to gear oil and is a spec regarding yellow metal compatibility. As this is not really gear oil, it does not apply. PSM is however yellow metal safe.
Sent from my XT1060 using Maxima
asand1 is offline
Old 02-20-2015, 04:25 AM
theWalkinator's Avatar
I did that 2 month ago, replaced drive side CV boot, the boot kit I got from Advance Auto comes with a snap ring and a pack of grease, to separate CV joint requires some convincing, I just hold the shaft down with me left hand, and slammed the joint with a 3 pound hammer, give it few good slams and you should be able to knock it out, cleaned the old grease in the bowl, I used a can of brake cleaner, put everything back, works fine, I do have to remove the shaft from the transmission though.
theWalkinator is offline
Old 02-20-2015, 04:46 AM
Turbobink's Avatar
Always another option ...
Turbobink is offline
Old 02-20-2015, 05:00 AM
I saw some split boot that glues together, but not this bolt-on type, where can you get it?
Old 02-20-2015, 05:30 AM
CS_AR's Avatar
I learn something new every day..
CS_AR is offline
Old 02-20-2015, 05:44 AM
njmaxseltd's Avatar
That split boot is junk.
Replacing the boot is relatively easy. Pulling the axle will make things much easier and you will not lose all your trans fluid.
njmaxseltd is offline
Old 02-20-2015, 11:25 AM
asand1's Avatar
Split boots are junk. They will leak in pretty short order.
asand1 is offline
Old 02-20-2015, 11:31 AM
asand1's Avatar
I have had both axles out before, this is not my first rodeo. I know for a fact I will lose most of my fluid. I beleive automatics won't lose much fluid though.
asand1 is offline
Old 02-20-2015, 11:59 AM
Turbobink's Avatar
Can't you just drain your fluid into a clean container, do your fix, strain your fluid and refill your trans?
There might be a bit of volume lost but I can't imagine it'd be much.
Old 02-20-2015, 02:05 PM
asand1's Avatar
I will if I have too, I even have an extra quart of SM.
asand1 is offline
Old 02-20-2015, 02:38 PM
jholley's Avatar
I re-used fairly new ATF after cleaning it with a paint strainer a few years ago and its still pink. The AT has been shifting fine. Happened after modifying the VB, inserting new shift soleniods, and replacing 10 quarts of ATF. I bent the AT pan by carelessy over torquing a few of the 21 bolts. After installing a new pan I added that cleanly strained ATF. DIdn't want to spend a bundle on Amsoil synthetic ATF again.
jholley is offline
Old 02-20-2015, 02:59 PM
Turbobink's Avatar
^^^ I know a number of local shops that'll offer to retain your recovered fluid (based on the recency of it's change out of course), including my local Ford dealership, and encourage it's reuse.
As long as you're not introducing grit or other contaminants, I honestly think you're good to go.
Old 02-20-2015, 04:45 PM
asand1's Avatar
This is my fear. luckily my car is pretty clean underneath, I would just have to clean out my drain pan.
asand1 is offline
Old 02-20-2015, 11:43 PM
dwapenyi's Avatar
Get some old socks to use as a filter. The oil will probably go very slowly through it, but you could be doing your axle job while the fluid is slowly straining through.
dwapenyi is offline
Old 02-21-2015, 04:49 AM
Do be sure to update this if you can get the joint off as shown in the video.
I have a Raxle here that needs a outer boot.
ChrisMan287 is offline
Old 02-21-2015, 05:57 AM
asand1's Avatar
Will do. I'm going to try this just to prove a point and hopefully share another shortcut like the KS install.
asand1 is offline
Old 02-21-2015, 09:11 AM
When I did mine, I pulled axle out, no ATF came out, not even a single drop.
Old 02-21-2015, 10:28 AM
dwapenyi's Avatar
Manual tranny is different from automatic. You can lose a lot of gear oil when popping out the axle.
dwapenyi is offline
Old 02-21-2015, 10:43 AM
CS_AR's Avatar
+1
I'm trying to remember the amount. I definitely had to top it off again with the extra quart that I purchased to keep on hand for emergency repairs.
CS_AR is offline
Old 03-04-2015, 10:13 PM
asand1's Avatar
I placed my order for this expecting junk.
And got this
Was surprised and very happy to see an Empi boot, they don't get much better than that.
I pulled the joint out of the hub and attempted to remove the joint in-car, but I just could not get a good enough swing. After draining the MTF into a clean pan I pulled the shaft and replaced the boot.
The old boot has a small puncture wound that I think is from my strut work awhile back.
New boot installed.
asand1 is offline
Old 03-04-2015, 11:54 PM
dwapenyi's Avatar
Nice
dwapenyi is offline
Old 03-05-2015, 07:34 AM
asand1's Avatar
asand1 is offline
Old 03-05-2015, 09:17 AM
There is no need to remove the brake caliper, caliper mounting bracket and rotor in order to remove the axle.
Old 03-05-2015, 10:16 AM
asand1's Avatar
I didn't want to scar up the powder coating, and these brakes are bigger than stock, leaving less room.
asand1 is offline
Old 03-05-2015, 02:01 PM
asand1's Avatar
This is how I torqued the axle nut with my 150 ft/lb torque wrench.
asand1 is offline
Old 03-05-2015, 10:16 PM
uttadms31's Avatar
I have a 150 ft-lb torque wrench also but haven't had any luck finding an appropriate torque multiplier bar anywhere/online. Any recommendations? Also, could I just torque the nut to 150 ft-lb with my wrench, then add 1/4-1/2 turn or so with a breaker bar/pipe to get to near the 174 ft-lb minimum?
uttadms31 is offline
Old 03-06-2015, 06:11 AM
So the method shown in the vid worked just fine?
Old 03-06-2015, 06:56 AM
CS_AR's Avatar
Thank you for posting the information. I think it will help members save some $$$.
CS_AR is offline
Old 03-06-2015, 09:07 AM
PowerTotheMax's Avatar
Did any grease get on your rotor? I noticed you have no shield. I am also thinking about doing that brake upgrade.
PowerTotheMax is offline
Old 03-06-2015, 01:51 PM
asand1's Avatar
If you're referring to the first post and Deming the joint in car, no I could not get a good enough swing with the hammer.
asand1 is offline
Old 03-06-2015, 01:52 PM
asand1's Avatar
No, joint is located far enough back from the wheel and rotor that it could not get them greasy.
asand1 is offline
knight_yyz
11-01-2015 01:34 PM
londonflu
09-19-2015 02:33 PM
Bonka
09-14-2015 11:18 PM
DBear
09-14-2015 08:33 PM
Quick Reply: Outer CV boot torn.
