hit a pothole while auto was changing gear
Old 01-25-2015, 07:54 AM
max ride 41's Avatar
and it sounded like the trans mis-shifted and i skipped a gear. seems ok visually, don't know if my alignment is off or not. it felt ok coming home, but something sounds like its clunking, only on turns. had that issue before, wondering what could've broke, tie rod, end link, strut? ideas on what to check here, thanks
max ride 41 is offline
Old 01-25-2015, 08:11 AM
JoshG's Avatar
so when u hit the pothole the gear shifted itself since its auto?
JoshG is offline
Old 01-25-2015, 08:25 AM
D.Stillwell's Avatar
This happens to me unless I turn traction control off. This has only been true since I lowered the car tho, never on stock suspension
D.Stillwell is offline
Old 01-25-2015, 08:42 AM
Fakie J Farkerton's Avatar
You have a 4th gen with a traction control button?
Fakie J Farkerton is offline
Old 01-25-2015, 08:49 AM
nope, looks like I overlooked the 4th gen part.
Oops
Old 01-25-2015, 09:15 AM
JoshG's Avatar
im guessing thats on 5th gens? lol
JoshG is offline
Old 01-25-2015, 09:31 AM
Old 01-25-2015, 10:23 AM
kinda was in between gears and felt like it skipped a gear. i've heard it do this before, usually when i let off the gas and then i step on it.
Old 01-25-2015, 10:28 AM
george__'s Avatar
It'll be fine
george__ is offline
Old 01-25-2015, 10:38 AM
CMax03's Avatar
Maybe it's the CV joint, maybe it extended the joint...Or just jack it up and inspect your suspension and driveaxles....
CMax03 is offline
Old 01-25-2015, 03:55 PM
that's my plan, gotta get an inspection soon anywho
Old 01-26-2015, 05:40 AM
njmaxseltd's Avatar
The 99 4th gen has traction control. Got it on my SE-L.
njmaxseltd is offline
Old 01-26-2015, 05:56 AM
Learn something new everyday.
Old 01-26-2015, 09:56 AM
CMax03's Avatar
That's nearly every car....
CMax03 is offline
Old 01-26-2015, 12:26 PM
not my car, never had it
Old 01-27-2015, 10:07 PM
Climaxx's Avatar
I'm gonna throw some possibilities out there as I'm not seeing adequate information.
is it constantly making this noise when you turn? in other words can you make it make that noise whenever you want? if yes, sound like cv axle or strut bearing.
if it only happened when you hit that bump I wouldn't worry about it. it was probably some sort of "glitch" from that bump. imagine if you were running and stepped into a pot hole you didn't see lol
Climaxx is offline
Old 01-31-2015, 07:05 AM
Quickywd01's Avatar
On my '99 se auto I heard a clunking noise when turned full especially on an incline. But I also had it acting as if though it was stuck in a high gear when driving off from a stop. It blew a spider pin out the case one day. Car still drove home. I have a "new" rebuilt auto trans in that '99se, lmk if you need it and if your car isn't rusted away a.k.a. easy to work on then I'll help you replace it.
Quickywd01 is offline
Old 01-31-2015, 04:59 PM
rusted away??? pleeze, you know me and my max by now, all fixed and shines like new. what's a spider pin??
matts95max
09-09-2023 01:52 AM
sctludwig
09-01-2022 01:32 PM
dcardello
09-03-2015 11:44 PM
sdotcarter
09-02-2015 09:53 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: hit a pothole while auto was changing gear
