Changed my sparks plugs with platinum at 100K now at 215K should I replace?
Old 01-05-2015, 09:54 AM
Max40
Maxie40's Avatar
The last time I replaced the spark plugs on my 1995 SE was about 8 years ago when it had 100K on it. Had platinum spark plugs put in back then. Now I am at 215K should I replace the spark plugs? Car runs smooth even though it idles a little high when I first start up. Just replaced my intake manifold gasket and MAF. Any suggestions would be appreciated.
Maxie40 is offline
Old 01-05-2015, 09:57 AM
Mateen995's Avatar
I would suggest to do it since its been over 100k since & to avoid idle/running issues later on
Mateen995 is offline
Old 01-05-2015, 11:04 AM
njmaxseltd's Avatar
100K on platinum plugs is enough, change them.
njmaxseltd is offline
Old 01-05-2015, 06:34 PM
uttadms31's Avatar
Another reason to change them...gives you an opportunity to see if you have any oil in your spark plug wells
uttadms31 is offline
Old 01-05-2015, 07:06 PM
KP11520's Avatar
Overdue! NGK of Course!
And as long as your coil packs survive the assault, it's quite easy!
The 4th Gen "How To's" section has details.
KP11520 is offline
Old 01-06-2015, 05:19 AM
D.Stillwell's Avatar
What do you mean by "coil packs survive the assault"?
And yes definitely time to do plugs, especially considering the cost is maybe around 30 bucks and on the vq30 plugs are easy as heck....You should clearly do it after 100k, no need to even ask.
D.Stillwell is offline
Old 01-06-2015, 05:40 AM
max ride 41's Avatar
$hit, i do mine at 50-60,000 on the nose.
max ride 41 is offline
Old 01-06-2015, 05:58 AM
Yup, I've opted to go this route myself. I use NGK Iridium IX and plan to change every 40-50k since its so easy and cheap.
Old 01-06-2015, 08:31 AM
KP11520's Avatar
Just that if they are original and 16 to 20 years old, to be ginger with them throughout the process. If one or two decide to give trouble after being "disturbed", we all know what that means. LOL
I wonder how many times a plug has to fire to go 100K miles. Even the platinum erodes after that amount!
KP11520 is offline
Old 01-06-2015, 12:36 PM
Rit
Rit's Avatar
If all of your driving was at 60 MPH, then your engine would have turned about 250 million revolutions, so I think that each spark plug would fire 125 million times during the 100K miles.
(more or less !)
Rit is offline
Old 01-06-2015, 03:31 PM
Fakie J Farkerton's Avatar
Originally Posted by Rit
If all of your driving was at 60 MPH, then your engine would have turned about 250 million revolutions, so I think that each spark plug would fire 125 million times during the 100K miles. (more or less !)
Well THAT just happened.
Fakie J Farkerton is offline
Old 01-06-2015, 03:51 PM
rhonster's Avatar
if you're idle revs are high, turn the ecu screw to the right of the gas pedal. should be around 600 when the engine is warmed up.
rhonster is offline
Maxboy23
08-21-2015 11:02 AM
Turbobink
08-15-2015 07:20 AM
Balkins
08-12-2015 06:39 AM
1992maximase30
08-05-2015 09:27 PM
maxima297
08-03-2015 12:50 PM
Quick Reply: Changed my sparks plugs with platinum at 100K now at 215K should I replace?
