After a year..i have decided to get back on my dek turbo swap
Hey guys finally got the car running smoothly but my slim fan arent coming on..here's how I wired it:
Blue and green to harness is tied to blue on slim fans. Black wire is to black wire. Butt ended the yellow.
Did I do this right? Cause they arent cutting on
Hook up a diagnostic tool or a scangauge etc and monitor your actual temps.
Fans will kick on LOW at 203F and HIGH at 221F.
If you turn on your AC, the fans should both instantly kick on.
Those are very close to the temps I measured after replacing a defective thermostat today. I used a scangauge to verify what temp the aftermarket autozone thermostat opened at.
Thermostat opened: 180f
LOW fan speed: 202f
HIGH fan speed: 220f
Those are the temps of using nearly 100% distilled water. I later backflushed the coolant system, ran distilled water 3 more times, then added Nissan green coolant.
Hard to say without seeing the wiring diagram instructions for your slim fans.
For reference, you'll want to look at pages EC-430 through EC-433 of the FSM for the wiring schematic of the OEM fans.
Copy/paste from my phone notes:
Radiator fans wiring
pin 1 = white/black stripe - low speed positive connection
pin 2 = white/blue stripe - high speed positive connection
pin 3 = white/red stripe - low speed negative connection (ground)
pin 4 = solid black - high speed negative connection (ground)
YOU WANT THE HIGH SPEED SIDE.
CorollaULEV
30
08-09-2021 08:11 PM
Finkle
09-27-2015 09:53 PM
