Alignment after replacing control arm??
Old 04-19-2014, 11:27 AM
Patm-a32's Avatar
Hey guys swapped out my control arm on the drivers side today, including bushings & new ball joint. I previously got an allignment mabey a month or so ago, the axel and the tirod were not removed or messed with while changing out the old arm and in the new one, should i get an allignment ? I know u should whenever you mess with suspension components but if the allignment was spot on before changing the arm will i need one ? If so how long can i go before i should really consider getting one
Patm-a32 is offline
Old 04-19-2014, 12:35 PM
DennisMik's Avatar
I would get the alignment. The bushings could have been worn and allowing the wheel to be mis-positioned during the last alignment. Plus the new lca might be made with slightly different dimensions.
DennisMik is offline
Old 04-19-2014, 12:46 PM
I'd get one.
Call the spot you had the alignment done at and tell them that the car is pulling to the left. Maybe they'll re-align it for free since it's only been a month. Some places have warranties like that.
ChrisMan287 is offline
Old 04-19-2014, 04:30 PM
96i30azn's Avatar
May be obvious but make sure you're done with replacing suspension/steering components before going for alignment. Also, there are places that'll check to see if you actually need an alignment first before charging you.
96i30azn is offline
Old 04-19-2014, 04:41 PM
Les7311's Avatar
I replaced BOTH control arms and didn't align after. Car drove straight, but inside treading wore bald after 2 months.
My tires were only 3 months new - - grrrrrr.
MUST get realigned, especially if you change any suspension parts.
Replace both arms while you at it.
Les7311 is offline
Matt93SE
05-24-2019 02:58 PM
Jeffesernia11
08-23-2015 06:09 PM
maxocar
08-21-2015 12:57 AM
soon2ownmax
08-13-2015 02:19 PM
laparka66
08-06-2015 09:36 AM
Quick Reply: Alignment after replacing control arm??
