Finishing up a swap
Finishing up a swap
I'm putting in a lower mileage 3.0 in a friends 97 I30 this weekend. I've already dropped the old motor & trans out the bottom today. How can I put the motor and trans back in from the bottom being that I usually pull it out the top with trans out... I'm.doing this with handtools and jackstands
Can you set the TPS and IACV adjustment? Keep it running. If the replacement engine has some carbon buildup it may take a few hours to burn off. Did the injectors and coils come from the original engine or the replacement? Also, did the previous engine have an oil burning or fuel flooding problem that may have caused the cats to still be restricting exhaust flow?
I recently had a low mileage replacement engine installed that inherited idling and misfire problems from the previous engine because I requested the original "leaking fuel injectors" with original rails be moved to the replacement. Two different mechanic shops missed diagnosing the bad injectors that were dumping too much into the engine. Also, the cats were clogged up that caused an assortment of run issues that may have been caused by too much unburned fuel.
Ok... I will check it in the morning... The replacement engine was mine which I know had no issues... I did the swap because his old motor had major oil leaks! I'm thinking about rebuilding & stroking the motor, is it worth it
It's time to invest in air tools & a trans jack etc... I pulled the motor up the top the lowered the car gradually then pulled the motor up until I could line the crossmember up...Then put the trans back up... A day & a half won't bad by myself! Thanks members cuz I'm still willing to learn... Any members in Richmond surrounding areas
NWP engineering fully swapped a 3.5 (VIAS VTCs ALL operational on 3.5 computer) into his 3rd gen maxima and now its the fastest all motor maxima in the world;
http://www.nwpengineering.com/videos.html
NO NO NO NO NO!
That stuff will sometimes stop the leak but more than likely just clog your radiator and/or your heater core!
"Repair in a CAN" = temporary fix that will cause a bigger issue later. Its like putting a band-aid on a bullet wound.
This goes the same for the crap they sell during the summer to "fix your AC"....dont ever but anything that includes "leak repair" into your AC system unless you want to replace your Condenser, evaporator, dryer and possibly your compressor. Just use the standard straight R134.
Fix it correctly the first time.
regular stop leak:
http://allwheeldriveauto.com/why-you...n-your-subaru/
It's not as black and white as YOU're trying to make it :wink:
back on topic now, shall we?
it also is specific to the 2.5l engines only. Also, it is REQUIRED to keep one's engine warranty on those motors as well. It's not relevant to the conversation here though, so let's just let it go.
OP knows what the issue is...he stated it several posts above..it's the crossover pipes.
The stop leak for the Subaru is not for leaking hoses like the case here. it's for attempting to remedy a design flaw in the head gaskets. So NO it's not relevant to this discussion. Besides, YOU said earlier that you "can't guarantee it won't clog your maxima's radiator"...which is one hell of an endorsement for putting it in a car
Ghost - You need to replace those crossover pipes if you can, or JB weld them from the outside. Don't use a can of anything.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
