PS Belt, "start bump it on", why?
I've been reading threads about replacing the PS Belt... and I've seen the suggestions about using the starter to bump it on.
Is the starter bump option used to avoid trying to deal with the horrendously impossible to reach bolt on the rear? Or, after you get the bolt loosened is there still a problem getting the new belt on?
[Also: has anyone tracked down the engineer who designed that back of the starter bolt and beat him senseless yet? Because I'm up to be the guy who does it if a volunteer is needed ]
OK, thanks. I did get in there and get the bolt loose, but what a PITA.
I did the adjustment for now, I just wanted to be prepped for when I go back in to replace the belt in a couple months (long story).
I just replaced both my belts on Tuesday. Loosening the bolt on the backside was easy with a long extension, swivel, and 14mm shallow socket. Go in between the cross member and the transmission with the extension and then place the swivel socket on the extension with your other hand. In my case a deep socket was too long and put a bind on the swivel. I loosened the 12mm tensioner bolt with a 1/4" socket on a little 1/4 breaker bar. The tensioner could then be adjusted wit a 1/4" 12mm socket with a swivel and extension.
It was very easy and the belts don't squeak any more.
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
trungg86
09-04-2015 04:58 AM
