Car not moving/grinding noise
I just got done changing my wheel bearing and I got everything done I put car in reverse and no movement just a loud grinding noise and the speedo goes up. I tightened the bolts with and impact and not sure what else to do?
Go back to the wheel you just worked on, the CV joint has separated under the boot. Easy, but messy fix. Cut the clamp off the boot, it's full of grease. You'll see the joint has come off the spline shaft. Put it back on, try not to loose much grease, then put the boot back over and zip tie it closed nice and tight.
You may have to remove the lower strut bolts to pull the hub out enough to get it together.
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
