Really clean engine internals over 200k miles
Just did the front most valve cover gasket the other day and was quite shocked at how clean the internals of the engine are.
I know, :
So I'll try to get some up when I do the back cover.
Some basics:
Original owner, only ever used Castrol GTX, 3,000 - 5,000 miles oil changes.
Never did any sort of engine flush, sea foam crap, nothing. Just a nice golden color on everything, absolutely no sigh of sludge or build up anywhere.
This engine really is designed to run forever and I believe Castrol GTX is one of the best oils on the market. You can keep your Mobil 1 synthetic high priced crap, the proof is in my engine.
I know, :
Some basics:
my car as 150k miles on it, last time I did my valve it was pretty clean, and golden like you said, I also use Castrol GTX on my last oil change, that's the only one I ever did since I bought the car, maybe it was clean before that or not, but it was pretty clean.. take a look http://forums.maxima.org/4th-generat...sket-pics.html
When I did my front valve covers at 225k miles mine didnt look as clean, so i tired removing most of the gunk and buildup, changed PVC valve and hoses and changed it every 4k miles, gotta reseal the valve covers as They are seaping again on the rear, and didnt use the right sealant on it grrrr!!! Going to see if any changes were made on engine condition runs better though at 252k miles
Castrol GTX is one of the best, if not the best, oil out there. Only reason I use mobil1 is because walmart sells it for half price and only because it's 0W-40. If I wasn't using 0W-40 I'd be using castrol gtx. Now if only walmart sold the GERMAN castrol 0W I'd be even happier.
That looks great......and a little bit weird at the same time. There's like no oil hanging around. Most times I see valve cover pics where there's a nice sheen of oil coating all the engine parts. That sheen gives off a nice golden brown hue. With yours it looks like Mobil 1 did its job, then literally all of it disappeared back into the oil pan, waiting for you to start the car again
When I had my 4th gen I would use Mobil 1 as well. I would also buy it at walmart because it was so much cheaper than anywhere else.
You mean top of the head? It's supposed to drain out. The coating that remains on the camshaft and shims is enough to lubricate during start up. There's a term for that. But look closely and you'll see plenty of oil in place where the camshaft lobe pushes against the valve lifter.
Also, the camshaft bearings are holding plenty of oil.
Team STILLEN
08-10-2015 04:29 PM
