Need some help please...
Just bought a clean 99 maxima GLE with only 99 thousand miles on it... It has the ABS SLIP and TCS OFF as well as SES all on... I was told its because my ABS sensor need to be replaced... and all the lights will come off.. Is this true? also my front right wheel is clicking when making slow turns... I looked an the CV Boot is split open... Is this a serious problem and do i need a new boot or the whole axle? Never had a maxima only civics... This is my first buy for 2000 dollars...
Step one- find and replace the bad abs sensor, no guarantee but it's likely it will fix all the lights
Step two- just get a new cv axle. I have had good luck with NAPA
Step three-drive and pick up the ladies B-)
I can do the first 2 but step 3 im married lmfao... thanks though...
check the codes as far as the ses light. just depends on what the codes are and if they are related to the abs problem. usually the abs doesnt have to do anything with the ses because that has to deal with emissions. emisiions has nothing to do with your brake system.
zazon
04-17-2005 07:37 PM
