Ebay headers at 152.95
Old 01-19-2014, 09:53 AM
DJ_Nismo's Avatar
http://www.ebay.ca/itm/Performance-H...vxp=mtr&_uhb=1
someone have tried those ??
the price is so low... ok maybee they are not good for 300hp but for a dealy driver that have a value of 2000$ ??
i'm not sure if a brand new warpspeed would be a good choice
DJ_Nismo is offline
Old 01-19-2014, 09:57 AM
max ride 41's Avatar
fitment is always a guess on these cheapy egay headers. better off with a warpspeed.
max ride 41 is offline
Old 01-19-2014, 10:37 AM
ACee's Avatar
I have them on my 2003.
ACee is offline
Old 01-19-2014, 10:46 AM
Fakie J Farkerton's Avatar
I have those headers on my '97 3.5 swap.
Not bad.
Warp-y though.
Fakie J Farkerton is offline
Old 01-19-2014, 10:54 AM
deathwobble's Avatar
I've had many bad experiences with cheap headers
deathwobble is offline
CMax03's Avatar
Post some pictures of them and what kind of issue you may have had with fitment if any? I don't care if fitment is an issue that way I have a chop saw and Fab skills!
CMax03 is offline
Old 01-19-2014, 11:22 AM
Fatboy98maxima's Avatar
well if anything the Y-Pipe alone is worth it LOL
Fatboy98maxima is offline
Old 01-19-2014, 12:33 PM
ACee's Avatar
Since I have an 03, I had to add 2 o2 bungs for the upstream sensors and I used the non-foulers for my 2 downstreams.
The hardest part for me was the removal of the rear heat shield. I ended up taking the valve cover off to get it out and just went ahead and replaced valve covers and gaskets when I was in there. I can try to take some photos if you want but there were already some on here.
As far as fitment. I ended up removing the three (six total) bolts that came in the actual header and tack welding in grade 8 bolts that I bought at autozone. The nuts and bolts supplied with my set couldn't hold the torque that I put on them so I put the grade 8s in their place.
If you replace the bolts, then make sure to get fine threaded grade 8 with nuts to match.
ACee is offline
Old 01-19-2014, 02:20 PM
Simardfosgate3's Avatar
I too would be interested in pictures of the headers from the engine bay and below if possible.
Ive got an 03 Maxima and cant see myself throwing down the cash for even just the obx headers for my model. So naturally these seem like the best option for me.
Simardfosgate3 is offline
Old 01-21-2014, 02:24 PM
6cyl-97maxima's Avatar
I may just try these on my 97. Since I need a whole new exhausted anyway and the only local options would be some crappy crushed bent system. Surly this cheap eBay system would offer better numbers over a stock exhaust. I'll be sure to post if I do try them.
6cyl-97maxima is offline
Old 01-21-2014, 03:33 PM
IMO, you're asking for a potential headache going for these. These headers probably won't give you any gains over stock, only the ypipe will due to the removal of the precats. With that said, just go for a reputable y-pipe like Warpspeed or Cattman.
The Wizard is offline
Old 01-21-2014, 03:38 PM
TexasTex's Avatar
I'm guessing this is the same for an 02?
TexasTex is offline
thank you, unless cattman or better, warpspeed is better for added hp.
Old 01-21-2014, 03:48 PM
ACee's Avatar
I can get you some photos but you might need to give me a day or two.
I have actually been debating on trying the obx headers because they are longer individual tubes. Just spending the money, you know?
Not sure the quality of bolts or the o2 bung locations on the obx....
But I am prepared to relocate the bungs and remove and install adequate bolts if needed.
Let me see what photos I can get for you.
You got a dyno to back it up?
One question for me on the obx is how do you fit the rear bank header up from below? Because it is welded to the y pipe and I only see installing from the top.
ACee is offline
Old 01-21-2014, 03:53 PM
TexasTex's Avatar
I'd like to see that too. Not questioning it, just curious.
TexasTex is offline
Old 01-21-2014, 04:13 PM
ACee's Avatar
Me too.
I have yet to see anything but hearsay.
Yes.
ACee is offline
Old 01-21-2014, 04:23 PM
TexasTex's Avatar
Yes.
I figured, but it seems there's always a slight change, somewhere from year to year.
TexasTex is offline
Old 01-21-2014, 05:26 PM
ACee's Avatar
Too many photos to post.
Start here and go through my photo bucket...
http://s993.photobucket.com/user/ant...tml?sort=3&o=0
If you select the other album within photo bucket there are more photos.
It took a while to learn the installation process, but I could do it now in about 3-5 hours. Including removal of old and not including drilling out broken studs or modifying the headers that are supposed to bolt right in.
ACee is offline
Old 01-21-2014, 05:52 PM
Me too.
you can't see hearsay
Old 01-21-2014, 05:53 PM
ACee's Avatar
ACee is offline
Old 01-21-2014, 05:59 PM
that's great if you have a garage and a tool bench and wan't to spend all that time for little to no gain. i've been perfectly happy with the warspeed y, eliminated the pre-cats and felt a nice little jump. i'm not going to dyno a mostly stock max, i can bet it's a 10- to 15 hp gain. not much, but the stock headers are good enough for me.
Old 01-21-2014, 06:04 PM
ACee's Avatar
If my stock precats wouldn't have taken a dump on me and not to mention these were all that were available at the time, then I would have kept it stock or maybe purchased something else.
And little to no gain is still hearsay.
If a y was made for my o3 that would have eliminated my precats, then I would have went with the y.
ACee is offline
Old 01-21-2014, 06:21 PM
TexasTex's Avatar
You can when it's typed out.
TexasTex is offline
Old 01-21-2014, 07:27 PM
not, it's hearsay so it doesn't exist and can't be proven in a court of maxima.org
Old 01-21-2014, 08:16 PM
TexasTex's Avatar
TexasTex is offline
Old 01-21-2014, 08:23 PM
carsnwomen91's Avatar
i never been around the headers but i thought the headers are mounted on studs (stock)?
carsnwomen91 is offline
Old 01-21-2014, 09:06 PM
Threads come through the y, no studs at the top.
Old 01-21-2014, 11:48 PM
JeEvE's Avatar
Set of headers I had did not have flat flanges so one bank had an exhaust leak..
JeEvE is offline
Old 01-22-2014, 01:39 AM
TexasTex's Avatar
Wow, that's BS.
TexasTex is offline
Old 01-22-2014, 03:40 AM
ACee's Avatar
Actually, I think stock is called exhaust manifolds and aftermarket are called headers.
ACee is offline
Old 01-22-2014, 04:27 PM
Climaxx's Avatar
exhaust manifolds = headers
headers = exhaust manifolds
potato-puhtawto. lol
Climaxx is offline
Old 01-22-2014, 04:39 PM
TexasTex's Avatar
Agreed.
TexasTex is offline
Old 01-23-2014, 07:00 AM
IMO, you're asking for a potential headache going for these. These headers probably won't give you any gains over stock, only the ypipe will odue to the removal of the precats. With that said, just go for a reputable y-pipe like Warpspeed or Cattman.
I'm sure your correct, but here is how I am looking at it. Warpspeed y-pipe is apx. $200+ Canadian and that's all you get, well flex pipe too. This is apx. $160 Canadian and not only do you get the y-pipe but you get headers and all required gaskets. If there is fititment issues with the headers then I just simply wouldn't install them. Either way I would still be getting the y-pipe for less than a warpspeed one. Quality control would not be as good but as far as gains, y-pipe to y-pipe, IMHO, there shouldn't be a whole lot of difference between the two, (generic VRS. Warpspeed), since as you stated its the eliminated pre-cats that give you the real gains.
Old 01-23-2014, 12:19 PM
You're making a big assumption that if you don't use the headers, that the y-pipe will bolt up no problem. I'd bet money that it won't work.
Old 01-23-2014, 01:07 PM
schmellyfart's Avatar
Correct.
I had a set of cheap eBay shorties 4 years ago, only installed the y pipe and the y pipe flanges were a good 1/2" or so off from the stock exhaust manifolds.
schmellyfart is offline
Old 01-23-2014, 01:13 PM
ACee's Avatar
Correct.
What do you have installed now?
ACee is offline
Old 01-23-2014, 02:24 PM
DJ_Nismo's Avatar
it say on the item description:
Each Set is Tested and Dynoed to Make Sure the Fitment and Performance to Meet our Goal
Direct Bolt-On Installation
with 98.2% Positive feedback
I buy it now and will update with pics soon
I already have a custom 2.5inch catback, the Y pipe is 2.25 so I will need something to correct this but I don't think it's a big issue..
My main issue is my wallet lol
DJ_Nismo is offline
Old 01-23-2014, 02:32 PM
Well, I hope this doesn't turn into a case of a penny wise and a pound foolish.... Good luck! and keep us posted.
Old 01-23-2014, 02:33 PM
DJ_Nismo's Avatar
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=161187853259
I just took this one
205$ canadian shipping included
DJ_Nismo is offline
Old 01-23-2014, 03:07 PM
ACee's Avatar
Remember my posts man. I just installed a set of these a few weeks ago. Looking forward to your updated post (s).
http://s993.photobucket.com/user/ant...?sort=3&page=1
ACee is offline
Quick Reply: Ebay headers at 152.95
