How to tell if I have a standard or limited slip auto trans?
Old 11-19-2013, 09:26 AM
pottzie's Avatar
Just checking on getting a replacement transmission (automatic) for my '97 Maxima. The first question they ask is "Limited slip or standard?" I didn't know there were two types offered, and was told that I probably have the standard one.
Any way to know for sure?
pottzie is offline
Old 11-19-2013, 09:40 AM
Fakie J Farkerton's Avatar
Originally Posted by pottzie
Just checking on getting a replacement transmission (automatic) for my '97 Maxima. The first question they ask is "Limited slip or standard?" I didn't know there were two types offered, and was told that I probably have the standard one. Any way to know for sure?
Check the stickies.
http://www.pbase.com/cleanmaxx_brian/image/19276707
Fakie J Farkerton is offline
Old 11-19-2013, 10:49 AM
pottzie's Avatar
Didn't see any help in the VIN guide, although thanks for pointing it out to me, might help down the road. All I see is something saying that Maximas can be either a32 or A33. No idea what the difference is between those two. Does that determine which tranmission?
pottzie is offline
Old 11-19-2013, 11:07 AM
Aflion's Avatar
A32 is 4th gen Maxima, A33 is 5th gen Maxima. It's probably open diff. I think LSD was offered in the later Maxima's and I30's. You could jack up your car, spin a front wheel while its in neutral, and if the front wheels spin in opposite directions, it's open diff.
Aflion is offline
Old 11-19-2013, 11:10 AM
dot dot dot ...
NmexMAX's Avatar
Might check the tranny code too.
A = open, V = VLSD
NmexMAX is offline
Old 11-19-2013, 04:28 PM
jholley's Avatar
Originally Posted by nmexmax
might check the tranny code too.
A = open, v = vlsd
+1
Originally Posted by jholley
the metallic plate is on the passenger side firewall. Transaxle identification is on the bottom of the plate.
Re4f04a = open non slip
re4f04v = vlsd slip dif
re4f04h = hlsd slip dif
All 4th GEN Maximas sold in the US are non slip. Only Canada got slip differential.
jholley is offline
Old 11-19-2013, 07:09 PM
deathwobble's Avatar
Do a neutral drop. If only one tire spins it's a open diff if both spin you have a limited slip :-)
I'm just kidding don't really do that.
deathwobble is offline
Old 11-20-2013, 01:53 PM
pottzie's Avatar
Yep, it's regular non slip, just as everyone has said it would be. Thanks.
pottzie is offline
Old 12-30-2013, 10:55 PM
1992maximase30's Avatar
+1
Re4fo4h = hlsd???
I didn't know the maxima/i30 had these
1992maximase30 is offline
Old 12-31-2013, 01:42 AM
Originally Posted by 1992maximase30
Re4fo4h = hlsd??? I didn't know the maxima/i30 had these
99.9%sure that hlsd was introduced in 2002.
Old 12-31-2013, 04:16 AM
ABIGBRAIN's Avatar
Absolutely incorrect information right here.
ABIGBRAIN is offline
Old 12-31-2013, 10:04 AM
LTXMitch's Avatar
Go around a turn and stomp it. Your front right will spin through most of first gear.
LTXMitch is offline
Old 12-31-2013, 10:37 AM
Not at all a tell tale.
I have VLSD and it's not consistent on which tire wants to let go and when. Road conditions, etc.
OP figured it out anyways:
/thread
Miket2006
03-01-2021 03:55 AM
BobTX10
10-07-2015 08:43 AM
hayne
10-05-2015 11:53 AM
ef9
10-04-2015 08:43 AM
Quick Reply: How to tell if I have a standard or limited slip auto trans?
