3in exhaust
The y pipe. I'm 3in cat back
I have the MeganRace headers
Didn't Darren say there were gains with sparks old y pipe?
I just googled meagen headers 4th gen and saw cheap ass Custom Maxima type headers. Didn't see anywhere that it was clarified.
In any case, Sparks never saw any gains with his custom 3" y, and it sounded awful. I'm positive that's why he went back to the Cattman Y that comes with the headers, bad sound and no gain.
http://forums.maxima.org/7864834-post1.html
And that's on an NA VQ35. Pretty sure it would be the same for an NA VQ30.
Gen I Cattman's for 95-99 Maximas with the EGR modded for my 03.
Originally Posted by spraks03max
The non-equal length design was required to make the Y collector fit without making the costs much higher or hacking up the cattman piece, but it has very little effect on power, sound is the main difference.
I just googled meagen headers 4th gen and saw cheap *** Custom Maxima type headers. Didn't see anywhere that it was clarified. In any case, Sparks never saw any gains with his custom 3" y, and it sounded awful. I'm positive that's why he went back to the Cattman Y that comes with the headers, bad sound and no gain. http://forums.maxima.org/7864834-post1.html And that's on an NA VQ35. Pretty sure it would be the same for an NA VQ30. Gen I Cattman's for 95-99 Maximas with the EGR modded for my 03.
EDIT: never mind, read through the link and noticed he did that. Wish he would have tried equal length though, bet it would have sounded better. Also, did he have a resonator on the cat back? That could have helped with sound if e didn't.
Well i got the. Altima. Ser. Headers. With a. Wich are. Long tube. A. Equal length. Y pipe. With a. Cheap ***. Muffler. Un till i can. Save. Up. For a. 3In. Skunk2. Oh and. A nice. Big. Resonater
I may not have actual headers, but I am going to put a better Y-pipe on the dirty one day (BETTER THAN STILLEN?! NANI?!), does anyone know the piping diameter of cattman's? I have planned on doing 2.5" for each bank to a 3" going out to the catback (also deleting the cat w/ this y-pipe).
I understand your confusion as he never stated exactly what he had. We just know because it's our bud. Maybe some benefit would occur with it opening to 3" if they gradually get to 3 from union piece to end of flange, connect that to remaining exhaust system going 3". I prefer equal length just so the exhaust sounds better. I thought nothing negative comes from going 3" cat back on NA.
By the By.... I'm talking outside piping diameter throughout this whole post. Not the ID.
And the fabber, was the guy that made these headers....
http://forums.maxima.org/6th-generat...ic-inside.html
I'm building a 3" aluminum exhaust and I'm only going to step up the diameter right before my stainless resonated test-pipe on my y-pipe. You really want the exhaust to be scavenged from the primaries. Once the exhaust starts to cool and slow down, you should step it up in size. 2.25" secondaries with a 2.5" merge, then flare it to 3" just before or just after the end of the y-pipe should be best, unless you're running a roots blower or something... which you're not.
I'm not sure which technical jargon you're familiar with but the "Y-Pipe" or "Collector pipe" for the cattman headers would be the diameter I'm interested in.
Aluminum..... catback right?
Also what's that term for amount of flow area or something, because IIRC 2x 2.25's = 3.1" of flow so having a 2.5 is a bottleneck in terms of flow..... Someone correct me on this...
If so, join le club of awesome
Not too familiar with the jargon, but I think you wanted the headers to open up to 3" in at the flange where they join to the y pipe correct? I should have measured my cattman yesterday, I had it off the car to do some WB bung inspections.
I want the 3" to occur after both banks merge into one pipe, on the "y-pipe" for the cattman headers, that was my general idea.
Bank 1: Primary Header Piping 1 7/8ths? -> Primary Collector 2.25" -> 2.25" Secondary Tubing -> Secondary Collector 3" -> 3" Catback
The red bold portion is what I'm interested in having measured.
06-06-2017 02:01 PM
