Very weird steering problem help please!!!!!!!!!!
When I'm on the accelerator the car steers towards the right, once i let go of the accelerator and the rpm is dropping my car goes back to steering towards the left. Very unusual! its a 99 5 speed se
are you talking a lazy drift or like a hard torque steer? Is it when you're first starting to move, or every time?
Most FWD cars have torque steer and what-not, tha turns the wheel to the right by default (safety) when you whomp on it...
if it's just a lazy drift, then it's likely your alignment. ESPECIALLY since an alignment needs to be done when you screw with the steering and suspension system like you did.
Unless you wore your tires over that three week period, it shouldn't be them. Are they both new, same age, inflated?
i changed both the front tires with used tires. The guys are the tire shop told me they were good, i probably got played. Cus i felt the front tire on the passenger side and the inner part of it was smooth as a babies bottom, everytime im driving, out of no where it would pull towards the right.
if the inner part is worn on the right then before you got the alignment your front tires looked like this from above: |----/ Even after an alignment if you still have those same tires you will still feel a pull. This same thing just happened on the wife's car.
I changed my passenger control arm in the end of june and today when inspected sure enough the bushings are like bubble gum. The cause is a power steering leak coming from the high pressure hose and its dripping directly on top of the arm. So this might be the problem. right after i changed that arm the car was riding like a charm even with the ****ty tire..
lowpost99
05-16-2021 11:18 AM
pktaske
09-04-2015 08:40 AM
