Hesitating around 3500 RPMs?
Old 09-01-2013, 11:49 AM
King Ranzo's Avatar
Hey guys. So I just got a full tank of gas Friday night and right after I filled the tank, I was driving and I decided to mess around a bit with a friend of mine. As soon as I got past 3500 RPM, the car felt like it was missing a cylinder. It was just choking. Any idea what may be going on? The car didn't throw any codes and it still hasn't. The only codes I have in there are codes that were already there for the EGRC solenoid and MAP sensor.
EDIT: It also does it if I'm in third gear around 20 and I give it a bit of gas. I'm thinking fuel filter but I wanna get someone else's opinion.
King Ranzo is offline
Old 09-01-2013, 12:08 PM
bprice92's Avatar
Well I'd have to agree with you. Fuel filter would be a good place to start.
bprice92 is offline
Old 09-01-2013, 04:43 PM
King Ranzo's Avatar
Yeah. I already have a full tune up ready to go for it. Oil change, spark plugs, and a fuel filter. I just have to find time this week to do it.
Old 09-01-2013, 05:03 PM
xkazik's Avatar
I use to have the same problem, for me it ended up being a coil , it didnt throw a miss fire code but ended up being one , i coulnt figure which one it was so i bought a set of 6 used . after that the problem went away, i say do the plugs , filter if you still have the problem i would do the coil
xkazik is offline
Old 09-01-2013, 05:45 PM
tigersharkdude's Avatar
3k-4k issue
MAF
tigersharkdude is offline
Old 09-02-2013, 07:37 AM
King Ranzo's Avatar
I was hoping it wouldn't be MAF, but that's what I'm leaning toward. I'm gonna do the tune up I have and see if that fixes it. If not, I'll use my friend's intake and see if his MAF fixes it. If it does, then I'll get a new MAF
Old 09-02-2013, 07:39 AM
try cleaning your MAF with some CRC Mass Air Sensor Cleaner
Its like $10 at autozone
Old 09-02-2013, 07:42 AM
aackshun's Avatar
Everything you just stated are events where the ignition timing is the most aggressive.
I throw my chips in on ignition failure (Coil or spark plugs)
Or chitty gas.
If you think it's the maf, un plug it, try some high load acceleration... Meaning accelerating from a low speed, high gear w/ as many of accessories on as possible (heavy load)... The try to accelerate w/ 3rd gear @ 20mph or 4th gear @ 25mph.... Still misfires then viola... It's not your maf.
aackshun is offline
Old 09-02-2013, 09:38 AM
King Ranzo's Avatar
I'll try this first. I work at Pep Boys so discounts galore
Or chitty gas.
Then I'll give this a shot. If that's the case, I'm assuming bad gas.
Old 09-05-2013, 12:39 PM
cashoit's Avatar
Throw some chevron techron in that bish!
fo real!!
cashoit is offline
Unclejunebug
04-02-2016 05:42 AM
ef9
10-04-2015 08:43 AM
Need help
23
10-02-2015 08:56 AM
JoshG
51
09-21-2015 10:41 PM
Quick Reply: Hesitating around 3500 RPMs?
