Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-27-2013, 09:31 AM   #1
Points: 10,983, Level: 69
Points: 10,983, Level: 69 Points: 10,983, Level: 69 Points: 10,983, Level: 69
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Transmission leaking from driver side axle input shaft seal
I have a 95 5spd and noticed a leak coming from the axle seal on the drivers side. It seems pretty straight forward in that if I replace this seal, it should stop the leak.
My question is whether something inside the transmission caused this seal to start leaking or if the seal just went bad?
How long do I have before I need to have this seal replaced?
Thanks,
Matt
__________________
matts95max is offline   Reply With Quote
Old 08-27-2013, 09:45 AM   #2
Points: 18,395, Level: 86
Points: 18,395, Level: 86 Points: 18,395, Level: 86 Points: 18,395, Level: 86
Activity: 53.2%
Activity: 53.2% Activity: 53.2% Activity: 53.2%
the seals wear out naturally over time. The rubber dries up, the constant rubbing of the axle as it turns all eventually doom the seal.
When exactly do you need to replace it?
A) Before all the oil leaks out
or
B) You get tired of the mess it is making.
DennisMik is offline   Reply With Quote
Old 08-27-2013, 09:56 AM   #3
Activity: 4.4%
any way to check the oil level in the transmission?
__________________
Old 08-27-2013, 10:09 AM   #4
Points: 5,284, Level: 46
Points: 5,284, Level: 46 Points: 5,284, Level: 46 Points: 5,284, Level: 46
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
* Deleted for incorrect information
metalgod3082 is offline   Reply With Quote
Old 08-27-2013, 10:21 AM   #5
Activity: 53.2%
^^^ Ignore that, that's for an automatic transmission. There is no dipstick for the 5 speed.
Remove the oil filler plug and see if you can detect oil in there. the pluf is on the front of the transmission. See page 9.
http://boredmder.com/FSMs/Nissan/Maxima/1995/MT.pdf
Old 08-27-2013, 10:45 AM   #6
Points: 35,333, Level: 100
Points: 35,333, Level: 100 Points: 35,333, Level: 100 Points: 35,333, Level: 100
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Send a message via AIM to njmaxseltd
The likely cause of the leak isn't necessarily the seal itself, but rather the differential bearings loosening up and causing unwanted play. If you can feel any side to side (not in , out) play in the drive shaft where it goes into the transmission, then replacing the seal isn't going to do you any good. You need to replace and re-shim the diff. bearings. This issue is very well documented on here. Do a quick search to find more information before you replace the seal and wind up with the same leak.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 08-27-2013, 01:11 PM   #7
Activity: 4.4%
So I can check for play in that bearing by moving the axle from side to side while everything is still bolted up to the car?
From what it looks like, if it is the diff bearing, the transmission has to be completely taken apart to fix it?
__________________
Old 08-27-2013, 01:38 PM   #8
Activity: 11.4%
Yes
Old 08-27-2013, 04:02 PM   #9
Activity: 4.4%
thats terrible.
Old 08-27-2013, 04:30 PM   #10
Lethal's Avatar
Points: 7,964, Level: 60
Points: 7,964, Level: 60 Points: 7,964, Level: 60 Points: 7,964, Level: 60
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Hey join the club! Mine just started leaking a couple weeks ago. Although mine was caused from the amazing mechanics at my local Nissan dealership not replacing the axle seals when they installed a new clutch. For your piece of mind, mine has been leaking for at least 2-3 weeks and the transmission fluid level is still full.
Seems like a pretty easy job, I got quoted something like 160$ for the dealership to do it on one side. Don't know if I'm going to buy to 'seal puller' and attempt this myself or just take it in.
Lethal is offline   Reply With Quote
Old 08-28-2013, 05:39 AM   #11
Activity: 4.4%
If you decide to do it, make sure you don't scratch the inside casing where the seal sits when you pull the seal. That could be a way for the fluid to leak through the outer edge of the seal because the scratch kind of give the oil a pathway. ?? Not sure but better to be safe than sorry.
I dont care about doing the seal job, I just don't want to crack open the tranny to do the diff bearing job. Ive long viewed the tranny as a big scary monster. lol
Old 08-28-2013, 06:01 AM   #12
Points: 14,242, Level: 77
Points: 14,242, Level: 77 Points: 14,242, Level: 77 Points: 14,242, Level: 77
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
To check fluid level, open the fill plug in the front on level ground. Put your finger in the hole. The fluid level should be just under the plug.
When I fill, I fill until it comes out and then wait until it stops coming out.
As for the axle seal, I would pull the axle and inspect the seal. You should be able to tell if it is damaged. Of course that means that you have to drain most of your tranny fluid.
__________________
2012 Infiniti G37S Liquid Platinum
2000 SE 5spd Black/Black
Timing Advanced to 17 BTDC ; Place Racing CAI ; Unorthodox Racing UDP ; Exedy Stage 1 Clutch ; Cattman Headers; Cattman Mid Pipe ; Tokiko Illuminas/Eibach Springs ; Pacesetter STS ; Courtesy FTSB ;
Best 1/4 mile: 14.39 @ 98.03 2.195 60'
1996 SE Auto Pearl/Black
Stock - 300,000 Miles +
Max_Gator is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
