Strange AC problems
Old 08-26-2013, 12:16 PM
Igor911's Avatar
Strange AC problems
Hello all,
Recently have been having issues with my AC. I just recharged the system and the AC is blowing super cold. However, abotu 2 weeks later the system acts up and blows warm at times.
Seems to alternate between warm air and cold air. Any ideas what I can look into?
I checked under the hood and no leaks (that I can see)
Igor911 is offline
Old 08-26-2013, 12:36 PM
Amerikaner83's Avatar
so you recharge, then it is fine for two weeks then acts up again. AT THAT POINT can you recharge again and it be ok for awhile again?
If so, you have a leak
Amerikaner83 is offline
Old 08-26-2013, 01:20 PM
bullet187's Avatar
Possibly your A/C is overcharged. Check the low side psi for about ten minutes and see if it goes above 50 PSI.
bullet187 is offline
Old 08-26-2013, 02:10 PM
Igor911's Avatar
Thanks, I will go out and get a gauge. If it is overcharged, how do you drain it some?
Igor911 is offline
Old 08-26-2013, 03:37 PM
njmaxseltd's Avatar
If it starts to blow warm when it's really hot then blows cold once the temps are down a bit, then it's very possible it's over charged.
njmaxseltd is offline
Old 08-26-2013, 04:30 PM
bullet187's Avatar
Find out if the system is overcharged first.
litch
123
01-04-2024 07:01 PM
hcarter1112
42
07-18-2022 03:35 PM
gavin68
09-18-2021 12:36 PM
HerpDerp1919
09-29-2015 02:02 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Strange AC problems
