quick question about my RACK ;)
SEARCH
Iv'e never seen a drain plug on any PS system
NO. Do not run the pump dry. Add some and start for a second or two, then repeat.
and why no drain plug?
i was thinking about unscewing a line,and starting it up to run all the fluid out. good idea?,bad idea?
What I did with a helper was pull the ps return line from the reservoir, drain, cap the nipple on the reservoir, and fill with Mobil 1 ATF, return line directed to a bucket. Helper starts car and turns wheel back and forth while I keep adding ATF to reservoir. You may need helper to stop car so you can keep up. Don't let it run dry, air in the system can create a frothy strawberry milkshake mess, and low fluid level once the bubbles come out.
03-12-2020 12:06 AM
mikeg75
11-30-2015 05:12 PM
