I have a dam.....
Old 04-23-2013, 02:23 PM
El_BoriMax's Avatar
I have a dam.....
I have a dam misfiring or sputtering problem. I thought it was the coilpacks so I replaced all 6 coilpacks and it was fine for like a day. Then it started to like choke. If you hit the gas pedal all the way it takes forever to speed up. Then it would like kick in hard when it wants to and goes fast. Its so annoying I wanted to know if anyone have any suggestions that I can try.
I searched but mostly everyone just have a coil pack problem. Or temp sensor
El_BoriMax is offline
Old 04-23-2013, 02:25 PM
MaxFiyah's Avatar
did u use oem coil packs?
MaxFiyah is offline
Old 04-23-2013, 02:30 PM
Fakie J Farkerton's Avatar
Fakie J Farkerton is offline
Old 04-23-2013, 02:34 PM
El_BoriMax's Avatar
No I bought ones from a store I know it was aftermarket. But it should be fine cuz I had to maximas and the other one I had I also bought all six and it was fine.
Old 04-23-2013, 03:51 PM
asand1's Avatar
After market coils should run fine, they'll just throw a code is all. Have you scanned for codes?
asand1 is offline
Old 04-23-2013, 05:42 PM
blacka69's Avatar
Hey, I was having this same problem..tested coilpacks they were fine plugs only have about 1500 miles on them...it had become really bad over the weekend. I was suggested it may be a faulty injector, not having time to do injectors I swapped out the maf. The car's idle evened out considerably and needless to say acceleration is back chirping tires first and second gear...I didn't notice you saying you tested or maybe for you clean the maf, if not give that a shot and see what happens. If you know someone with a working maf maybe swap it just to test it out Good luck
blacka69 is offline
Old 04-23-2013, 05:45 PM
theblackone3.5's Avatar
aftermarket coils suck **** for our car!!!!! You need nissan oem coils asap!!
theblackone3.5 is offline
Old 04-23-2013, 06:47 PM
blacka69's Avatar
Very true, but as stated i had the same exact issue, misfire - sputtering - lack of acceleration - hesitation -sucky gas mileage-it was the maf, try and swap with someone,if this is also your issue replace maf and put back the oem coils, keep the aftermarkets as emergency spares imho
blacka69 is offline
Old 04-23-2013, 07:18 PM
WTF?'s Avatar
Before you spend anymore money, tighten up the plug gap.
WTF? is offline
Old 04-23-2013, 07:38 PM
back2basics's Avatar
I'd go for the MAF as mentioned above and you will want to look at the throttle position sensor.
I had the same issue and got codes for coils and the maf, so i said screw it and replaced all of the coil packs with OEM and same for the maf. This took care of a couple of the issues but I was still having a hesitation issue as soon as I stepped on the gas.
I did a little research and replaced the Throttle position sensor with an OEM unit, calibrated it, and bingo...no more problem...finally!
back2basics is offline
Old 04-24-2013, 08:26 AM
cashoit's Avatar
If its just a cylinder thats misfiring then focus on THAT cylinder. If the problem is common to all cylinders then its prolly the MAF.
cashoit is offline
Old 04-24-2013, 04:39 PM
Derpington's Avatar
My bet is injectors, i have aftermarket coils on 2 of my cylinders with the other 4 being OEM and the aftermarket ones throw no codes. Buy/Borrow a multimeter and check the coils and injectors.
Derpington is offline
hokiemax
09-28-2001 12:31 AM
Quick Reply: I have a dam.....
