Need to replace signal plate
Hey all, I have a 99 maxima with a 5 spd. It looks like I need to change the signal plate on the flywheel because of a p1336 code. Since i will need to remove the transmission anyway i figured ill go in and change the RMS and upper oil pan seals on the engine. Im also going to be changing out the axles and clutch for safe measures.
Anyway my question is does anyone have list readily available of things i will need as far as seals and parts go. Ive pulled the tranny and changed the axles before so am comfortable doing the work, i just don't want to forget a little seal and end up making it take longer for not planning right. I want to order things this week so if anyone has any input it would be greatly appreciated. Thanks!!
Also i think my steering rack may be leaking, would it be worth it to do it now since the tranny is out, or can i do it later without removing the tranny?
For seals: rms, front and rear half moon seals, and about 2-3 tubes of rtv of your choice(I use black)
The steering rack would probably be easier with the trans out, but still possible with it in.
