So i'm looking to install fog lights
Old 03-25-2013, 09:31 PM
Calden__003's Avatar
I found all the how to install fog lights threads and stuff. But my question is does the connectors match for all of the different fog lights? or do I have to have the specific 95-96 fog lights because the connectors don't match newer ones.
I have a 1995 maxima, and I was considering retrofitting some of the 97-99 fog lights into the bumper of my car if i can't find some factory 95-96 fog lights.
Calden__003 is offline
Old 03-25-2013, 09:59 PM
Old Timer
d_warner's Avatar
If you're going to go through the work of retrofitting the housings into the bumper, then the connectors shouldn't be any concern really. I haven't had my 4th gen in a long time, but the work that would be needed to make the 97+ housings fit is more complex than getting a couple of waterproof connectors and making the wiring work. IIRC the 97+ housings were preferred by many anyways because they didn't break like the 95-96's.
d_warner is offline
Old 03-25-2013, 10:08 PM
ShocknAwe's Avatar
the 97+ are a different shape so its more work than bolting it up. Have CHrisman retrofit the 95-96. I like them better
ShocknAwe is offline
Old 03-25-2013, 10:16 PM
Max139617's Avatar
I have everything you need to make this happen . Ill shoot you a pm
Max139617 is offline
Old 03-26-2013, 07:11 AM
Thanks for the help guys. I was only considering the retrofitting route because it's so hard to find fog lights for my 1995 or they're wildly expensive.
Old 03-26-2013, 08:00 AM
Old Timer
d_warner's Avatar
I understand completely bro. They were hard to find back in the day when I had my 4th gen.
When it comes down to it, let the wiring be the least of your concerns. That will be the easy part, especially if you just solder, shrink wrap, and add your own new waterproof connectors.
Don't let us discourage you from trying the retro-grade. That can be half the fun sometimes. I was just suggesting to not get hung up on the wiring.
Good luck.
d_warner is offline
Old 03-27-2013, 12:37 AM
maxinout93's Avatar
Ive got a 95 and I just installed my fogs last month, I got mine from the local pull a part brakets, lights and stalk for $20. It was plug and play pretty much along with cutting out the holes in the bumper.
maxinout93 is offline
Old 04-01-2013, 09:49 PM
Sorry to bump this thread again, but do the H3's just connect directly to the electrical connector behind the bumper? if so, does the electrical connector also have the seal that keeps the light in place? or do i have to go find the special part that goes between the electrical connector and the fog light housing?
vingodine
45
05-21-2016 12:46 PM
EuroDriver
09-14-2015 06:08 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
98nismomax
08-13-2015 12:44 PM
Quick Reply: So i'm looking to install fog lights
