Schmelly's swap thread
Old 01-05-2014, 03:40 PM
  #41
schmellyfart's Avatar
Thanks! I'd love to swap in a 6mt, just gotta wait for the right one to come along.
schmellyfart is offline
Old 01-05-2014, 08:22 PM
  #42
deloa84's Avatar
A 6 speed aye??
deloa84 is offline
Old 01-05-2014, 08:37 PM
  #43
Originally Posted by deloa84
A 6 speed aye??
lol I've already told you I wanted a 6th gen HLSD. Harder to find but less work than swapping bellhousings with a spec v trans.
Old 01-05-2014, 08:47 PM
  #44
Maximeltman's Avatar
Hahaha...great job Schmelly! This makes me amped to try mine again, which keeps blowing hg's...but one day man...one day.
Maximeltman is offline
Old 01-05-2014, 09:14 PM
  #45
CMax03's Avatar
A 3.5 in this 98 would be awesome as well.....
CMax03 is offline
Old 01-06-2014, 12:07 PM
  #46
deloa84's Avatar
Yes I know I know. I just wanted a reason to post a GIF
deloa84 is offline
Old 03-30-2014, 04:40 PM
  #47
Quick update, the swap is finally CEL free, and passed the OBD emissions test legally.
For a while I had a reoccurring code, P1335, on my stock 97 5MT ECU that did not show up on either my 95 5MT or 96 5MT ECU's. Swapping out the crank sensors did nothing.
Fast forward to October 2013 when I had an occasional misfire from what I thought was a bad ECU connector. I replaced the connector and among all 100+ wires, I only crossed two of them a 12v line and a 5v line. Took me months of off and on troubleshooting to figure that out, and in the meantime none of my emissions sensors were working properly (since they were receiving 12v instead of 5v). After I corrected that power wiring issue, P1335 has yet to return.
tl;dr I have absolutely no idea what caused P1335 or what made it go away.
Old 07-11-2014, 02:21 PM
  #48
So I ran a little over 30k miles on my set of VQ30 NGK VPower Copper Spark plugs. Looking into other spark plugs I noticed VQ35 spark plugs were nearly twice as expensive, after some searching and comparison at the parts store it turns out that the threaded portion of the spark plug is longer.
So this whole time I've been running VQ30 spark plugs in my swap It made sense to me at the time, as the spark plugs that came with the engine were drenched in oil to leaking spark plug tube seals and my VQ30 spark plugs only had 10k miles on them. I had also assumed the spark plugs were the same since many other parts were interchangeable.
Now that the spark plug electrode is located properly in the combustion chamber, I am anxious to dyno again. My previous dyno with header back exhaust, nwp spacers, bop made 236whp and 221 ft lbs.
My fuel economy has also increased from mid 26s to a low 29. I only have one tank on these new plugs, but I will be sure to update as I put more miles on these plugs.
Old 07-11-2014, 05:21 PM
  #49
NSMO240's Avatar
I like to see these threads more and more, cause it just gets me closer to doing mine. what EGR system are you using?
NSMO240 is offline
Old 07-11-2014, 11:11 PM
  #50
EGR system was removed when I installed the 00vi back in 2010. I left the EGR temp sensor and solenoid plugged in. It used to randomly throw a code for low flow, but I haven't gotten that code in a few years.
Old 07-12-2014, 11:49 AM
  #51
NSMO240's Avatar
ah, i got you. is yours federal spec or cali?
NSMO240 is offline
Old 07-13-2014, 02:18 PM
  #52
Quickywd01's Avatar
I was waiting for the day your figured all of this out. Those spark plugs will def show gains. I knew something was up but I didn't want to say it because it looked like you did everything legit. Stupid spark plugs. I can't wait for your new dyno.
Quickywd01 is offline
Old 07-18-2014, 10:30 PM
  #53
Cali spec, 97 SE manufactured in late '96.
By all means speak up next time, its how we all learn -myself especially.
I have quite a bit of intake mods in the works along with a tune for the next time I hit the dyno. Now that I have the proper spark plugs, I am a bit more confident that I can hit my goal of 270 whp without fooling around under the valve cover.
Old 07-26-2014, 11:13 PM
  #54
Black Lion
maxprivate's Avatar
Nice to see it coming along. I thought getting rid of EGR would cause issues passing inspection, I guess not. Not planning on boosting?
maxprivate is offline
Old 07-27-2014, 12:33 PM
  #55
We don't have inspection over here, just emissions testing. I'm actually considering sourcing another EGR system to install on my 3.5.
I don't have any plans to boost it.
Old 07-27-2014, 01:46 PM
  #56
Black Lion
maxprivate's Avatar
Hmmm I see. Why would you want to reinstall an EGR? I don't think there is anything beneficial about it. Just supposedly cleaner emissions.
I already have a V1 on my 3.0 so will be installing that on the 3.5
It was suggested I do ACL race bearing, main bearing, and Rod bolts so it will handle the boost. I heard 3.5 rods are weak link of the 3.5
BTW you got rid of your 3" Cattman exhaust?
Old 07-27-2014, 03:46 PM
  #57
The EGR helps to reduce fuel consumption by reintroducing spent exhaust gases into the combustion chamber under certain conditions by lowering combustion temperatures, running a leaner air/fuel mixture, as well as allowing the throttle to be opened more to take advantage of the higher engine efficiency while still maintaining the same power output as when the EGR is off and the throttle opened less. The EGR does help improve tailpipe emissions, but frankly I'm more concerned with fuel economy.
I plan to hook up a simple LED to the EGR solenoid to see when the EGR operates, and possibly adjust the EGR operation with Nistune.
Nice, I remember reading Cardana's swap thread. He had the same intentions, but I don't think he has gotten around to reinstalling his yet.
Nope, still have my Cattman 3". I'm considering making a lighter exhaust, but that's a ways down the road.
Old 09-22-2014, 09:05 PM
  #58
New personal best of 13.994@99.88. Best trap of the night was 100.78, and a new best 60' of 2.20.
Running 225/50R15 Toyo Proxes R888 on two 3rd gen wheels up front. With these tires, my 60' averaged high 2.2x. On my street tires I will usually be lucky to manage a low 2.3x. I'm still working on improving my launches, I had the best results launching at 3-3.5k with these tires after a burnout.
I also had a lot of trouble shifting into 3rd gear, moreso than usual, which resulted in many mid 14 sec passes at 98mph or so.
Wild Horsepass Motorsports Park (formerly Firebird International Raceway) in Chandler, AZ
Track Elevation: 1080ft
Density Altitude at time of my best run: 3560ft
Current setup:
+02 VQ35 w/3.0 timing, 7th gen injectors (Green Denso's), DE-K FPR, return fuel setup on a VQ35 fuel rail
+AEM Dryflow, 3.5" velocity stack, Q45 MAF, OEM 7th gen intake tubing
+PFTB
+NWP BOP
+NWP 5pc spacers
+Altima headers w/ 3" y pipe back
+2J-Racing UDP
+Nistune ECU [7000 RPM rev limit, AFR low 12s, ignition timing left untouched]
Race weight: 3016lbs with driver, tools, battery jump pack, and a little over 1/4 tank of gas.
Old 09-23-2014, 12:10 AM
  #59
dwapenyi's Avatar
Nice your car broke 100 and I cant believe that, fully loaded, your car weighs just a tad over 3000 pounds.
dwapenyi is offline
Old 09-29-2014, 08:02 PM
  #60
Thanks, I've broken 100 a few times since the swap. Looking to pick up a couple more mph once I finish up with my bbtb and tune it.
I have done a fair amount of weight reduction including but not limited to aluminum bumper reinforcements, coilovers, cf hood, no spare/jack, no heatshields, gutted trunk, mechless head unit, power mirrors removed, 17lb lawn mower battery. With a full tank of gas it should weigh in around a hair under 2900lbs without driver, tools, and jump pack.
Old 09-29-2014, 09:58 PM
  #61
CMax03's Avatar
Just seating there it doesn't look fast at all! Nice sleeper!
CMax03 is offline
Old 09-30-2014, 07:39 PM
  #62
Thank you sir.
Old 11-18-2014, 12:20 PM
  #63
Lightly modded
95maxrider's Avatar
I am using a 2003 3.5 fuel rail, with a de-k fpr and the lower half of the original 3.5 supply fuel line as the return adapter. I originally had the same adapter I used on my de-k fuel rail, but that o ring leaked on me.
So I take it you're not using an AFPR, just an OEM DEK? Great thread!
95maxrider is offline
Old 11-18-2014, 04:53 PM
  #64
That is correct.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
JonBlz
10-05-2015 06:02 PM
ef9
10-04-2015 08:43 AM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: Schmelly's swap thread
